Installed TD's, SES light came on....
You should have just gone to a speed shop and had them delete the codes for ALL the emmissions stuff. It'd be about the same price as O2 sims and work way better.
1. You have an exhaust leak close to your front O2 sensors.
2. From deleting the cats, you have lost the huge amount of heat the front O2 sensors needs to function properly, and thus act a fool and throw bogus codes at you...most likely that the banks are running lean or rich...or they're having a problem switching back and forth between lean and rich.
I have the same problem right now. I deleted the cats...and boom, the car throws these codes at me!! It's so gangster, but that's the way it is. I have not attempted to fix the problem yet but I'm going to start this weekend. First, I'm going to jack the car up, lather up the passenger side piping with soap/water and then turn the car on and look for bubbles. If I can't find any, I'm going to spend $90 and buy a rear Corvette O2 sensor. Many guys have tried it and been successful. If for some reason neither of these work...and there honestly is a good chance that it won't; as many others have said,..."Welcome to the SES light club." If you have driven the car for a few hundred miles and noticed absolutely NO CHANGE IN PERFORMANCE, have the codes deleted out of your PCM...i.e. LS1 edit. If you car is jacked up and acting weird like mine is, DO NOT DELETE THE CODES...figure out what the problem is and fix it first. I'd love to delete the codes just to get that stupid light off, however, my car is idling hard...fluxuating RPM's...and at low RPM's, the car will sometimes shutter and bog down like it has no power or fuel to keep it running. Downshift however and go over 2k RPM's...the car runs fine.
Because of this, I don't think my problem is mechanical, i'm certain it is electrical, probably the same as your car. I just find it too much of a coincidence that the day I take my cats off, one of my pistons or cylinder chambers starts messing up, misfiring and running lean...etc. The sensors are merely in place to help the car run more efficiently...when they jack up, the car's performance gets jacked up. Don't let the car run in the open loop program that came from the factory. According to all these other LS1 techs, the program sucks and will drastically hurt your performace and gas mileage.
Long story short, you're almost a member of this SES light club. Just frustrate yourself a little more, spend more time and money trying to fix it to no avail...and you're in!! I really do feel for you as I am still having the same friken problem! If I get a chance to work on it this weekend, I'll try to remember and let you know what the deal is. Good mother f'ing luck!!
Nothing you do from the collectors back should affect the front O2's throwing a code, unless you are running straight headers, even then it probably wont even notice.
pdanrichey I am having the same issues you are having. Bad gas mileage, rough idle, hesitation, etc. I installed headers roughly 3 weeks ago and have been fighting with it ever since. I am throwing a P1153, So I guess I am a member.
Here is what I have done in an effort to rectify the issue:
2 New 13111 Bosch Sensors (C5 Corvette...., No affect)
Had Y-pipe/race pipes weld (No affect)
Noticed Leakage at collector, tightened clamp and used silicon. No signs of leakage (No affect)
Watched O2's With Snap On Meter, Both Switch Between 300-800
Fuel Pressure (55-60 Running, 55 and some leakage key on)
Spark Plugs (roughly 3K look brand new)
MSD Wires (roughly 3K also look brand new, feel tight, no havent checked resistance)
I could give a damn about the light being on but when it starts to run like crap I also get a little pissed. I have looked for burned O2 wires and plan on checking voltages when I get the time. The car didnt have any issues prior to the header install which makes me believe the fuel injectors, pump, etc are fine. Who knows...
pdanrichey I feel your pain, I have spent way too much money trying to figure out what the hell is wrong with my car...
If anyone has suggestions, advice please feel free to reply. Apprently we are not the only ones with this issue. Well enough of my ranting but this is Fing aggravating
What year is your car BTW?
still can't figure out why it has only been set twice in over 5k miles ?
damn, never mind! i just hate how removing the cats/installing a nice set of headers 20 years ago would only help performance...now days it just f%cks your *** and makes you go by the name Sheela
Oh The_Supra, where do you come up with these crazy antics!!...you stupid nagga. My SES light was flashing at me the other day...then my laptop started flashing at me, "Danger to Manifold." So I said "SHUT UP!!" as I slammed the laptop closed. Right then, I hit my 2nd stage of NOS, but all of a sudden, my passenger side floor panel unbolts and falls out while sparks fly up and hit me in the face. Needless to say, it was a rough day. Britton, didn't something similar to that happen to you in either your supra or charger...??...you copycat nagga!
