TB bypass
Old Feb 8, 2006 | 11:36 AM
camaroextra's Avatar
Originally Posted by BitViper
I resurrected this thread to ask a question.and to make an observation
I did the mod last week an can swear....that my throttle response is better...just response..Im not making any HP claims but when I "blip" the throttle between shifts...it responds MUCH better...anyone else experience this...Or does my medication need to be changed...
haha its ok, i felt the same way when i did my smooth bellows.
but then again, all that matters is how fast your car FEELS isnt it
Old Feb 8, 2006 | 01:08 PM
01Z28M6's Avatar
Originally Posted by BackinBlack02SS
That's fine if you want to cap it off. Won't be the first time someone hasn't taken my advice. The official GM parts name is the coolant air bleed hose. The pipe that connects both heads is known as the coolant air bleed pipe. It's there for a reason.
Thanks for posting this. I had a bit of trepidation when I capped mine off. I had read about the difficulty in getting trapped air out of the LS1. I haven't driven mine much since plugging the outlets but now that you have posted this, I'll be putting things back together.
Old Feb 17, 2006 | 12:45 PM
00Hawk#140's Avatar
What size brass fitting is needed between the 2 lines?
thx
Old Feb 17, 2006 | 12:57 PM
chaman's Avatar
I did the mod last week an can swear....that my throttle response is better...just response..I'm not making any HP claims but when I "blip" the throttle between shifts...it responds MUCH better...anyone else experience this...Or does my medication need to be changed...
That has a scientific explanation. Its called subconscious conditioning. You do the mod basically because you expect an increase in HP. When you run your car your expectation becomes a subconscious reality so the result is you THINK you got something but if you measure objectively your gains it would show otherwise.
Ill be here all week....next time we will talk about priapism....
