underdrive pulley
Old Jan 15, 2006 | 07:15 PM
00transamnh's Avatar
Default underdrive pulley
I need some advice on underdrive pulleys.... I know little about them or why they make a difference in hp (excuse my ignorance)...
Please help... id like to make this my next mod
Whats a good ud pulley to go with
Old Jan 15, 2006 | 07:17 PM
Lithium's Avatar
SSU's Drunk Typing Whore
ASP Pulley.
Expect around a 10hp increase.
Old Jan 15, 2006 | 07:19 PM
travisnd's Avatar
are there any downsides to getting the asp pulley? will the car still idle the same and everything?
Old Jan 15, 2006 | 07:22 PM
tomz240's Avatar
Anyone know of a site with instructions on swapping out the stock pulley with a UD pulley?
Old Jan 15, 2006 | 07:35 PM
Lithium's Avatar
Yes you can have charging problems if you are running a system. But that can be solved with the overdrive pulley.
Old Jan 15, 2006 | 07:36 PM
Lithium's Avatar
www.ls1howto.com
Theres another site that just has write up. I wil try to find it for you.
Old Jan 15, 2006 | 07:39 PM
tomz240's Avatar
I couldn't find it on LS1howto.com. Are you sure it is in there?
Old Jan 15, 2006 | 07:41 PM
Lithium's Avatar
Should be in the cam swap guide.
If search is working I will find the link for you.
Old Jan 15, 2006 | 07:47 PM
tomz240's Avatar
I think I found it. Is it in the cam and valve spring swap?
Old Jan 15, 2006 | 11:48 PM
Brandon35thSS's Avatar
i have the slp pulley and its easy as hell to install and no belt throwing issues and even a seat of the pants difference too! but it is expensive as hell just like most other slp products! lol!!
Old Jan 16, 2006 | 12:37 AM
camarodave98's Avatar
i got the slp, works great and only paid 150
Old Jan 16, 2006 | 02:30 AM
sidewayz28's Avatar
i bought the march fluid dampened one ill let you guys know how it is once i get it installed..im sure i wont be able to tell you much since im installing all my exhaust + the pulley at the same time and i bet there will be a huge difference!
Old Jan 16, 2006 | 07:31 AM
KILLERARMY's Avatar
Im getting my SLP pulley and loudmouth installed today.
Old Jan 16, 2006 | 04:07 PM
Will i have to worry about loosing my AC's power?
Old Jan 16, 2006 | 04:26 PM
Red99TA's Avatar
I'm runnin a pulley on mine w/o any aftermarket stereo equip (all stock) and I can notice the headlights dim a little at low rpms (near idle) and also they will slightly flicker at idle too...kind of annoying but I don't care that much. Could fix it with a different alternator pulley to make it spin faster.
Old Jan 16, 2006 | 04:37 PM
98TADRIVER's Avatar
any gains in the 1/4 mile with just the UD crank pulley? like a tenth?
Old Jan 16, 2006 | 04:48 PM
ClaySS01's Avatar
try this http://www.ls1camaro.net/sections.ph...ticle&artid=24
GTObsessor's Avatar
Yah about that... a heavily modded GTO (LS1) got 2 tenths from his. My passengers say the AC blows harder when my foot's on the gas now that I have the pulley... lol
Old Jan 16, 2006 | 04:50 PM
white_camaro's Avatar
i gained 1mph and 1tenth in the 1/4 with a powerbond(slp) pulley
Old Jan 16, 2006 | 10:15 PM
tomz240's Avatar
Thanks for the link clayss01. Looks pretty simple.
