Oil sender.. where do i tap into?
tried searching for about 2 hours now.. on here and google and im getting nothing reguarding LS1 engines..
to install sending units, unless you're trying to use the
stock sensor outputs to the pcm, in which case I have no idea.
It's really easy to remove and do. In reality probably easier then putting a
'T' behind the intake.
Hawk
When you tap the fixture be sure not to tap any deeper than 6 to 7 full threads from the top of the tap. Pipe taps are tapered and if you tap it too deep the threads won't seal (it will leak).
