Corvette O2 Sensors
Old Jan 26, 2006 | 04:41 PM
LS1BlackBird99's Avatar
Default Corvette 02 Sensors
Both of my front stock 02's blew last night on the spray. I heard everyone uses the corvette 02's as a replacement. What part number do I need to replace both sides? Where can I get them the least expensive and with the quickest shipping? My car is barely running and it is my daily driver. The dealership just plain sucks!!!
Old Jan 26, 2006 | 04:56 PM
BIRDONNOS's Avatar
Bosch 13111 rear corvette sensors.
Old Jan 26, 2006 | 05:03 PM
ND4SPD _SS's Avatar
yeah i used them too for the longer plug. you should check the C5 parts section. i bought 2 with a few thousand miles for $50.
Old Jan 26, 2006 | 10:54 PM
BlutVonSchwachen's Avatar
I would be more focused on why both o2 sensors would suddenly fail like that, exspecially at the same time...
Old Jan 27, 2006 | 12:28 AM
konryod215's Avatar
u can use rear o2s for the front?
Old Jan 27, 2006 | 01:06 PM
WhiteRhino's Avatar
Yes they're interchanable.The Corvette rears have a longer plug harness,so if you run headers you dont need extensions.They also have a higher watt heater,which also helps with headers due to them being father down stream.
Some people get o2 codes with headers.The Vette rears have helped some,but not others.Like they worked for me.
Old Jan 27, 2006 | 03:49 PM
BIRDONNOS's Avatar
both o'2s didn't fail just one side causing the car to run like sh_t, i recommmended replacing both of them since they have some miles on them.
Old Jan 27, 2006 | 04:24 PM
"Both of my front stock 02's blew last night "
Just going off what I read. You should be happy with the vette sensors. Get them from any auto parts store though. Most will have to special order them. You might get lucky at a chevy dealership as far as having them in stock, but they will be a little harder on your wallet of course.
