Does anyone believe the throttle body coolant bypass mod is worthwhile?
Old Jan 27, 2006 | 08:28 AM
C5XTASY's Avatar
Default Does anyone believe the throttle body coolant bypass mod is worthwhile?
I was debating this, but it is hard for me to believe that the air passing through the throttle body picks up much heat due to the high flow and very short period of time it spends going through it. I am thinking of porting my throttle body and that is the only reason I'm wondering if anyone has had positive, documented, results with this mod. Thanks.
Ed
Old Jan 27, 2006 | 08:50 AM
01formula6's Avatar
I don't think anyone would take the time to do back to back dynos just for this mod. Even if they did, the possible gains would be hard to measure due a couple hp variance between dyno runs. It only costs a couple bucks to do the mod and takes about 10 minutes. If you think it may be worthwhile then just do it.
Old Jan 27, 2006 | 09:01 AM
LS69TA's Avatar
It's one of those things that probably isn't going to help much, but can't hurt. However it probably gets pretty damn cold in MN, so you may have problems with the TB freezing up/sticking.
Old Jan 27, 2006 | 09:02 AM
HowellSoccer88's Avatar
I did it because its only a few dollars and it does make a little sense. If it's not hurting it then it's only making it better!
Old Jan 27, 2006 | 09:29 AM
JBIRD02's Avatar
Ed
well, think of a hairdryer. The air passes through a small space very quickly and it gets pretty hot. It only costs a couple of dollars, so why not go ahead and do it, if for no other reason to make taking the tb on and off easier.
actually, they did. If the "search" worked I'd try to pull up the link for ya, but I think it was worth like 5hp or something.
Old Jan 27, 2006 | 11:07 AM
C5XTASY's Avatar
You're right, it does get damn cold here! This winter has been fantastic, though...47 yesterday and 45 today...in January! Anyway, I store the car from late November through about April 1st (or whenever the salt is off the roads), though the temp sometimes snaps back down for a couple of days. Wish I were in Texas like yourself. Thanks for the feedback.
Ed
Old Jan 27, 2006 | 11:42 AM
LS69TA's Avatar
No problem. Didn't know you stored the car during the winter. I wish I could do mine the same way. The Tx heat sucks though. The weather's been great this winter, so I'm sure we'll suffer even more this summer.
Old Jan 27, 2006 | 12:14 PM
JohnnyC's Avatar
Anyone who actually believes that the throttle body bypass mod gives them any performance gains is kidding themselves. I am an engineer, and I can tell you that the air moves much too fast and the coolant is nowhere near hot enough to significantly change the temperature of the incoming air. I would post the equations here, but I think that would be a bit overkill. I guess it’s O.K. to remove it if you want to clean up the engine compartment, or make throttle body removal easier, but to say that this mod gives you any performance gains is laughable. And as for the “it couldn’t hurt” argument, there are lots of things that I can do to my car that couldn’t hurt; I could polish the inside of my oil pan and it couldn’t hurt, but I don’t do it because it’s pointless.
Old Jan 27, 2006 | 12:47 PM
WhiteRhino's Avatar
I agree with Johnny C.I could care less if it has a performance advantages.It doesnt take an engineer to tell those that have done it how much easier it is to take your tb off.Not having to mess with those coolant lines/mess any more.
Old Jan 27, 2006 | 01:23 PM
v8hunter's Avatar
One thing for sure is that it doesn't hurt...even if it only decreases the intake temperature a few degrees and adds 0.25% horsepower then it was worth it to me. Equations are great, but somtimes the real world results make the equations look stupid. Don't ask me about what I do for a living (hint I have same degree as you).
The throttle body bypass is one of those things that will be debated for many years to come...
Old Jan 27, 2006 | 01:29 PM
JohnnyC's Avatar
That's where the problem lies; it doesn't decrease the air temp a few degrees, and it doesn't add 0.25% H.P. It reduces the air temp 0 degrees and adds 0 H.P. It is a cosmetic mod at best. We don't have to pretend that it improves performance just to make ourselves feel better. Do it if you want the cosmetic benefits, just call it what it really is.
Old Jan 27, 2006 | 01:40 PM
LawmanSS's Avatar
Not only are there cosmetic benefits, but most aftermarket TBs don't have a provision for the coolant lines, so in some cases it's a necessity...FWIW.
MadBill's Avatar
I have a little more detail on this. I spent over 10 years as the Manager of Motorsports Technical Activities for GM of Canada. One of my jobs was to handle all the nut and bolt aspects of the Player's Ltd./GM Motorsport Series for showroom stock Camaros and Firebirds, which ran from 1986 to '92. In the course of our testing, I compared MAT values of the cars on oval and road course tracks, with and without coolant lines connected, to see if it was an area we would need to police for cheating.
I guess you could say the conclusions depend on one's definition of 'significant'. On a 75 degree ambient day we saw maximum temperature decreases of less than 10 degrees, which corresponded to a peak power gain of around 2 HP on these cars (~215 WHP with open exhaust). Conclusion: Although the gains are non-zero, anyone who thinks they can feel it with the butt dyno is deluding themselves!
BTW, the purpose of the coolant flow is to prevent throttle freeze-up due to water vapor from EGR gases.
Old Jan 27, 2006 | 01:42 PM
JBIRD02's Avatar
well, FWIW, my tb is no longer hot to the touch at full operating temp. like it was before I did the bypass.
Old Jan 27, 2006 | 01:52 PM
freakynipples69's Avatar
IMO, its a waste, even though in theory it seems like a good idea. The only reason I have it done is because the ported TB I bought didn't have the piping to hook it up normally.
Old Jan 27, 2006 | 02:16 PM
Lithium's Avatar
SSU's Drunk Typing Whore
There was a never ending thread on this not to long ago I believe...
Old Jan 27, 2006 | 02:39 PM
NO-OPTION-2002's Avatar
Very interesting, Mr. Madbill.
Why do non-egr cars have throttle body coolant passages?
Old Jan 27, 2006 | 02:48 PM
nuzee's Avatar
I did the by-pass after noticing that it took a long time for the intake tract to cool down between track runs. Not only was the TB very hot to the touch, but so was the intake manifold and the bellows & MAF in front of it (sometimes even the lid). After doing the by-pass, the whole intake tract is much cooler, even after the 20 mile trip to the track. Now I don’t have to wait long before making another pass. It has made a very big difference for me in that respect.
The other reason I did the by-pass was so that my VR Velocity stack wouldn’t melt. LOL!
Old Jan 27, 2006 | 04:05 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Mine used to be hot as crap and after the bypass it is ambient under hood temp.
Old Jan 27, 2006 | 04:29 PM
~JOSHUA's Avatar
I did the bypass for the de-clutter aspect and since it couldn't hurt.
Why the hell not? Who the hell cares? Why is the earth round? Why do Democrats suck *****?
