Best spark plugs!!
Old Feb 8, 2006 | 08:24 AM
sgarnett's Avatar
I use the Denso Irridiums. I'm under no delusions that they make more power, but with my toddler helping it takes about a week to change the plugs. I need plugs I can leave in for a while
Old Feb 8, 2006 | 09:30 AM
rgaynor85's Avatar
my car had the denso's i used the ngk's this time and it is runnin rougher i dunno i might go back to denso's or try delco's now
Old Feb 8, 2006 | 11:25 AM
Robinator's Avatar
I ran AC Delco Rapid Fire 3's the first time and it had never ran smoother. I have the TR55's in it now and they work just fine (although not as smooth) but the price difference was a no brainer. The delco's were $8/ea. Just glad I got a 50% off mail in rebate. I still am mad at the shop that pulled them out and replaced them during some motor work. They were in for 5k miles and they said they looked burned up!?
Old Feb 8, 2006 | 02:07 PM
FUN LS1's Avatar
Originally Posted by slt200mph
Why use those..your plugs tell you what is going on inside your engine..I like to look at mine regularly..I change mine every 8,000-10,000 miles..TR55's at a $1.68 a piece you might as well do it...I can change mine in 25-30 minutes..gap them at .055..
It has to have better flame propagation, doesn't it? When I took my stock plugs out after 75,000 miles they looked great. I haven't pulled the IX's to look at them since they went in 13,000 miles ago, so I don't know yet how well I'll be able to read the thin wire plugs after use; but I expect to see carbon or other extra stuff around the insulator like a regular plug. I'll check them when I swap cams next month, and then each time I check/swap the springs...
Old Feb 9, 2006 | 05:43 PM
ls1king000's Avatar
$1.89 at the NAPA store near me. Made in JAPAN oh well, is their even a plug made in usa anymore?
Old Feb 9, 2006 | 06:21 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
TR55's IMO.
Old Mar 2, 2006 | 07:37 PM
Powered By V8's Avatar
Smile
Well after this thread, I decided to pick up some NGK TR55's yesterday. Running good so far
Took me almost 3 hrs to put them in (and I coudln't get to the 8th one, plus I ran out of daylight). It was my first time so I figured it wasn't too bad. When I do them again, I could probably squeeze em out in a little under 2hrs
Old Mar 11, 2006 | 10:09 AM
slt200mph's Avatar
25-30 minutes for me I do not have smog crap to work around..I get 1-7 from the top and number 8 from under the car..
