TPS Voltage
Old Feb 8, 2006 | 09:14 PM
BlackLine's Avatar
Default TPS Voltage
I got done porting my throttlebody and i also milled down the throttle stop, I do not own any scanning software and was just wondering if i can use a basic voltmeter to set it?
Old Feb 9, 2006 | 07:58 AM
thunderstruck's Avatar
yes you can
Old Feb 9, 2006 | 10:18 AM
jimmyblue's Avatar
Moderator
You really want to grind the stop by ruler, not
voltage, but the voltage wants to be about 0.6
closed and below 4.7 open. If you run over 4.7
for more than a few seconds at a time you will
set a code.
Old Feb 9, 2006 | 10:31 AM
rgaynor85's Avatar
my autotap say 100% open but 4.4 volts i guess the % is incorrect or 100% according to stock spec is correct but i can still open it up a little?
Old Mar 2, 2006 | 04:32 PM
gun5l1ng3r's Avatar
How are we supposed to use a ruler to grind the bump stop (I mean, what measurements are we supposed to use)? How thick should it be? I have been searching for the correct way to do the bump stop mod, but I can't seem to find a good write up.
Old Mar 2, 2006 | 05:32 PM
daryl2cb@yahoo.com's Avatar
4.7 open is correct
Old Mar 2, 2006 | 10:17 PM
BlackLine's Avatar
i took my throttle body into work and machined the bump stop down and then taped a set screw and jam nut to adjust the throttle stop. pretty easy if you have access to a machine shop.
