Best Pulley for the Money?
It will drop 0.1/1 mph consistently.
Pulleys give you extra horsepower mainly because it is a LIGHTER pulley, not because its smaller.(or so i've heard)
If you have an A4, u would want to get an alternator Overdrive pulley, which is like an extra $30 or so and u can get it same place u get the underdrive pulley. Some people with A4's do not use the alt overdrive pulley and are fine, but most recommend it.
WIth a manual u generally don't have to worry about low power from the alt, unless ur running a system.
Whatever pulley you get, make sure it is SFI approved, i believe some of the earlier ASP's ones werent? someone correct me if i'm wrong.
I recently ordered the SLP one, and its a very nice looking pulley, being aluminum.
QUOTE]
Yes the pully is lighter because its smaller, but as Zeus stated earlier in the thread, the power comes from the pulley being 25% smaller than stock. That turns the accessories slower and allows more power to the wheels.
I was going to get the 25% crank pulley and the stock Alternator pulley.
What do you guys think?
Should I stick with the stock Alt pulley if I'll be sitting still in traffic? Or should I not get the pulley at all
