average hp gain on longtubes
Old Feb 17, 2006 | 12:30 PM
CaliboyTA's Avatar
weestro. Did u go over the axle or under the axle. What kind of suspension are u running.
Old Feb 17, 2006 | 12:38 PM
weestro's Avatar
I did 3"-->2.5" OTA and am VERY pleased with the setup FWIW. I'm currently running a prokit with Bilstein HDs and seem to only scrape over speed bumps and getting in/out of my garage . So I'm in the process of going back to stock springs with Koni's...
Old Feb 17, 2006 | 12:49 PM
CaliboyTA's Avatar
cool weestro. im doing almost identicle setup on what u doing. Gonna do konis Sa with stock springs, lower perch and heater hose mod. eventually im gonna do hotchkis springs but $$$ is limited. i was jsut worried about scraping on a lowered car.
Old Feb 17, 2006 | 01:06 PM
weestro's Avatar
yuup, exactly where I'm going with it. If I had done 2.5" duals front to back I'd probably be ok but I really wanted QTPs and they use a 3" collector so... Driving around I never scrape.
Old Feb 17, 2006 | 03:00 PM
CaliboyTA's Avatar
synergy motorsports is gonna install my true duals. Heres my setup. Qtp long tubes, dynatech cats, custom 3 inch x-pipe to 2.5in out back over the axle, magnaflow mufflers and tips of my choice. I was considering mecham tips but any suggestion on tips
Old Feb 17, 2006 | 04:24 PM
weestro's Avatar
I was thinking Mecham too but my muffs are mounted too close to the bumper so they're too long. I went with some polished stainless 4" slash rounds from Magnaflow. Should look pretty cool. Which Magnaflows did you go with? I went with 10416 which sound frickin AMAZING!
Old Feb 17, 2006 | 05:09 PM
CaliboyTA's Avatar
i dunno what model number im getting but its kinda like the bullet style but not as loud.
Old Feb 17, 2006 | 05:14 PM
CaliboyTA's Avatar
same mufflers as these
Old Feb 17, 2006 | 05:28 PM
weestro's Avatar
If those are 4" round straight thru then they're the same.
