Catylitic convert question
Old Feb 11, 2006 | 02:42 AM
LittleSlow1's Avatar
Default Catylitic convert question
If i remove the cats off my LS1 or put an off road Y pipe on my car will the computer throw a trouble code? The reason why i ask is that i wanna know if the car wil stil pass emissions. i under stand the car will pass if the computer has no codes stored.
Old Feb 11, 2006 | 02:45 AM
wmcrn's Avatar
yes it will throw a code
Old Feb 11, 2006 | 02:47 AM
TheBlurLS1's Avatar
That's what she said...
Yes the computer will throw a code if you remove the cats.
Our cars come with 4 O2 sensors, 2 on each side. The "front" 2 help make changes to the cars fuel/air mix, while the rear 2 only make sure the cat's are working. These rear 2 are the ones saying "hey this guy doesn't have cats!"
You can buy O2 simulators, AKA "O2 sims", which plug into the rear O2 sensor harness and replace the sensors. They simply trick the computer into thinking they work.
If you have to pass a visual inspection, you will most likley pass unless the place is really determined, but they can still fail you for not having cats in place, SES code or not.
A much better solution to the problem is to take the car to an LS1 speedshop or someone with LS1 edit and have the codes deleted. You will not have to run O2 sims and it will be UNABLE to throw the codes. You should be able to have this for less than the cost of O2 simulators.
