aftermarket air lid help
Old Feb 12, 2006 | 12:25 AM
TwoFast's Avatar
Default aftermarket air lid help
I've been hearing about how the slp lids tend to run against the underside of the hood, and was wondering if there is any other lid that doesn't rub and is a great fitting lid I can get. Also, is there a difference between a whisper lid and a regular aftermarket lid like the SLP lid? if so what are the differences and is one better than the other. sorry for the noob questions but I'm just not clear on these. thanks
Old Feb 12, 2006 | 12:59 AM
HowellSoccer88's Avatar
There was an article in a magazine that dyno'd and tested 6 different lids in the 1/4 but I dont know the link off the top of my head. I am sure someone could point you in the right direction. My whisper does not touch the hood as far as I know.
Old Feb 12, 2006 | 01:14 AM
wmcrn's Avatar
my slp lid doesn't touch the hood. fitment is great. don't know where you heard that from. but if you don't want slp there are plenty of others out there.
Old Feb 12, 2006 | 02:59 AM
Screamin_Z's Avatar
that article was in GMHP, I believe LG won the HP shootout BUT all of them were nearly identical (not enough to make a difference). What matters is getting rid of the factory air lid and putting one of the many aftermarket lids on. SLP's is a very nice lid, IMO factory quality. alot of the others are thin ABS or injected molded plastic and seem they will shatter into 1,000,000,000 pieces if it's cold outside and u rev ur motor (stress on the lid) but they don't...so choose whatever looks the best to u or the best price
Old Feb 12, 2006 | 03:44 AM
01Z28M6's Avatar
Default SLP lid touching the hood
My lid rubs my aftermarket SS hood. I can't say it will make contact with a factory hood or for that matter any other aftermarket hood. But there are minimal rub marks on mine.
regardz
Old Feb 12, 2006 | 03:53 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I have an LG lid that hits the hood since I put my FAST intake on.
Old Feb 12, 2006 | 04:02 AM
swoleguy's Avatar
I have a wisper lid and a stock hood with with no rubbing or problems.
Old Feb 12, 2006 | 04:10 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I didnt think that the WS6 guys ever really had a problem with it rubbing at all. I could be completely wrong tho.
Old Feb 12, 2006 | 07:54 AM
2_wacko's Avatar
I have the whisper lid fits great no rubbing on the hood.
Old Feb 12, 2006 | 09:10 AM
neonblack's Avatar
My stock lid actually rubbed the underside of my SS hood. Now that I switched to SLP's lid, I havn't had a problem. As far as which one is better, they all are pretty much the same. The testing done on each of them in the GMHTP article came to the same conclusion for the most part.
Old Feb 12, 2006 | 10:28 AM
ins0mnia24's Avatar
My SLP lid stopped rubbing after i trimmed off a 1/2- 5/8's of my bellow to allow everything to push in towards the t.b. tighter.
Plus when i installed it i didn't like how the 4 tabs of the lid were hanging out a little bit so i just trimmed the bellow until all 4 tabs were pushing tightly against the factory air box.
I have only seen a few other makes of air lids and i liked the SLP Better because it seemed like they used a thicker and more bendable ABS plastic than the other makes. But i agree a lid is a lid except for construction materials it's all preference.
Old Feb 12, 2006 | 12:24 PM
KrazyDan's Avatar
my slp lid rubs my hood.....
Old Feb 12, 2006 | 01:27 PM
TwoFast's Avatar
so is there a difference between the slp lid and the whisper lid, why do they call it a whisper lid? thanks for the help guys
Old Feb 12, 2006 | 01:30 PM
hurley711's Avatar
My lid rubbed, I stuck some AC foam to the underside of the hood where it touched the lid and it stopped any scraping on the lid. I never look under the hood so I didn't care that the foam was there.
Old Feb 12, 2006 | 02:39 PM
KrazyDan's Avatar
the reason i bought slp was because of the smog pump hose that goes to the stock lid works with slp. if you get ANY other lid, you will need to buy a breather filter as well. slp just looks cleaner.
i owned a clear tsp lid before the slp. it fit perfect and looked nice, but after about a year and a half it ended up braking.
Old Feb 12, 2006 | 03:33 PM
HeapaShifter's Avatar
I believe lots of the rubbing cases are from the SS and WS6 with the taller lower air box part.
Old Feb 12, 2006 | 04:21 PM
BBBBadSS's Avatar
My SLP lid rubs factory SS hood.
Old Feb 12, 2006 | 04:52 PM
Lss1350's Avatar
My SLP doesn't rub at all. Stock hood.
-j
Old Feb 12, 2006 | 05:59 PM
BriancWS6's Avatar
My SLP lid doesn't rub either. I have had it on both of my WS6 cars with no problems at all. I love how it looks, and the material it is made from matches everything else under the hood great.
Old Feb 13, 2006 | 06:16 AM
Juiced2000SS's Avatar
SLP lid here too, no rubbing. Fitment is great even with their bellows.
