!EGR & !AIR Pass CA Smog?
Old Feb 12, 2006 | 03:14 PM
RrCoX22's Avatar
Default !EGR & !AIR Pass CA Smog?
So after I remove my egr and air will i be able to pass emissions with them removed after a tune? Or is this a visual thing to where I would need to find someone to overlook the egr and air? Also will I even pass emissions with these removed and good tune? Thanks!
Old Feb 12, 2006 | 03:28 PM
HeapaShifter's Avatar
I don't know a whole lot about california emissions, but if pop the hood and look, you're be able to tell if they are there or not. It probably wouldn't pass the smog test either. They are both there to reduce the smog.
Old Feb 12, 2006 | 09:46 PM
WILWAXU's Avatar
Won't pass visual inspection.
Old Feb 13, 2006 | 04:21 AM
300bhp/ton's Avatar
Why bother removing them, neither have any affect on bhp so there's really no point.
Oh ok you can save a couple of lb's by removing the AIR system, but then again taking your shoe's off before you get in the car will do the same.
And removing the EGR may make more of an open space in the engine bay, but hay nobody drives round with the hood open do they.
IMO opinion leave them be, that way you won't have to worry about failing an inspection.
Old Feb 13, 2006 | 07:36 PM
6spd's Avatar
an inspection.
I can't drive a 6 speed for crap bare foot.
Old Feb 13, 2006 | 08:58 PM
2mffZ28's Avatar
not a chance in hell you will pass
Old Feb 13, 2006 | 09:23 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Not in Cali. Unless you find a friendy station...
Old Feb 13, 2006 | 09:28 PM
HowellSoccer88's Avatar
do they really do under-hood checks in CA? here in stl where everyone says it strict all they did was hook up the gas cap and then the obdII port and i passed with no air or egr and no cats
Old Feb 13, 2006 | 10:34 PM
Redneck Z's Avatar
You better believe it! All the rumors you've heard are true....only worse!
Old Feb 13, 2006 | 11:16 PM
Starz T/A 17's Avatar
Yeah I thought mostly everywhere did visual inspection. Here in NC they do and it sucks
Old Feb 14, 2006 | 11:56 AM
jason.sabovich's Avatar
I lived in CA for 24 years; they are ****'s about emissions. they will open you hood and check for the EGR and AIR. In fact they will even to check to make sure they are functioning! I know because they did that with a Hundai Excel I took and got smogged. After that it's the sniffer test. If you fail, they send the info directly to Sacramento; then good luck getting your car smogged or registered.
