Oil Filter
Old Feb 13, 2006 | 11:04 PM
C.J.'s Avatar
Default Oil Filter
Well search isnt working for me today for some reason so my question is what oil filter brand do you recommend when using Mobil 1 10w30 full synthetic.
Old Feb 13, 2006 | 11:12 PM
Starz T/A 17's Avatar
I know alot of people who use AC delco filteres but I run Puralator pure one b/c its suppost to filter better, I figure id use a better oil b/c I keep it in their longer then standard oil
Old Feb 14, 2006 | 12:03 AM
JoeyAnderson's Avatar
There are millions of opinions on this site.
I run a K&N oil filter.
Lots of folks run Mobil1 Filters.
Lots of folks run the Delco filters.
Old Feb 14, 2006 | 12:04 AM
TheBlurLS1's Avatar
That's what she said...
K&N part# 2006.
Its the longer (truck version) and offers a little more flow/filtration capacity. I noticed a slight boost in pressure when i switched to this from a Fram. K&N filters also have a 1" nut on the bottom, so you don't have to mess with filter wrenches or anything if you can't get it to spin loose.
Old Feb 14, 2006 | 12:09 AM
T-rex's Avatar
Does the 2006 K&N up the capacity to an even 6 quarts ?
Old Feb 14, 2006 | 12:10 AM
Keep in mind that when using K&N #2006, the nut protrudes below the oil pan.
Old Feb 14, 2006 | 12:39 AM
TheBlurLS1's Avatar
Mine runs right around 5.5-6 when i do a change.
This is true, but as long as you don't do too much 4x4 top truck challenge, you should be alright. The nut only hangs a tiny bit below anyway
