SLP 85mm MAF, should i descreen?
Old 02-16-2006, 09:12 AM
Hennytime's Avatar
i wouldnt descreen it (or take out my filter at the track) just because i have the kind of luck that if i d something will **** it up and im too poor to replace the motor now. but i think its only worth 2 hp or something, just do the tb bypass mod, probly make more power without risking an important part of your motor
Old 02-16-2006, 09:28 AM
STANG KILLA SS 2's Avatar
if your not willing to take any risks youll be running 12s forever.
risk is part of the game.
i already have TB bypass.
Old 02-16-2006, 09:35 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Descreen it. Seriously. This is something that will always cause debate.
If you are willing to take risks, the risk involved in doing this is most definitely screwing up your tune. If you can live with that, then have at it. We do have the technology to tune around this though.
Old 02-16-2006, 12:10 PM
no im getting it tuned again with the new setup. so im trying to decide if i want to remove it or leave it BEFORE i get it tuned...
Old 02-16-2006, 02:02 PM
FBodyPerformer's Avatar
Ive seen and heard nothing good about SLP MAFs. Unless you have it tuned for that MAF, it will screw up your car. Just what I know from experience
Descreening it just means it flows 150-200cfm more. If you are the person tuning your car feels it will be useful, then do it
Old 02-16-2006, 04:00 PM
again i am installing it BEFORE the tune! so it will be tuned for it...
Old 02-16-2006, 04:53 PM
SUX2BU's Avatar
If your going to have it tuned AFTER you put it on it doesn't matter what MAF you run. the problem everyone and their mom cries about is putting the MAF on and NOT getting it tuned right after. THAT could **** with your A/F ratio.
Old 02-16-2006, 05:17 PM
BADFNZ's Avatar
The people that say the screen is there for a reason are the same people that say cats are there for a reason, and they're running 13's. Descreen it.
Old 02-17-2006, 08:16 AM
haha ok fellas its comin off.
Old 02-17-2006, 08:36 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Originally Posted by STANG KILLA SS 2
i had my stock one descreened. should i rip out the honeycomb in this one? any NEGATIVE effects?
No and yes...It is a hit or miss thing.
Old 02-17-2006, 09:09 AM
gollum's Avatar
Better yet, do away with the MAF totally. Get a speed density tune.
Old 02-17-2006, 05:06 PM
  #32
i was, then decided against it. not the best for my application.
Old 02-17-2006, 08:38 PM
  #33
gollum's Avatar
The Granatelli is 85mm and comes without screen.
Old 02-17-2006, 10:08 PM
  #34
WILWAXU's Avatar
ok descreen it is
SUX and WAX.. what MAFs are you guys running?
I'm running a stock descreened MAF. When I upgrade to a 90mm intake, I'll be using a descreened 85mm.
Old 02-17-2006, 10:26 PM
  #35
SUX2BU's Avatar
ok descreen it is
I think mines the granatelli. no problems here but io got the car tuned with it on.
for what its worth i swapped out to a SLP 85mm trying to diagnose something and it dynoed the same EXACT numbers and A/F.
Old 02-19-2006, 04:09 PM
  #36
SUX
u always have good info to post. and u usually keep personal opinions to yourself. and just stick with facts.....
Old 02-19-2006, 07:13 PM
  #37
SUX2BU's Avatar
SUX
Thats what i'm here for.
Old 10-18-2007, 05:51 PM
  #38
98mysticZ's Avatar
where can i get the maf connector to go between the stock harness to the 85mm?
Quick Reply: SLP 85mm MAF, should i descreen?
