Kooks 1-7/8 x 2" stepped headers - clearance problems?
1) What sort of clearance problems (if any) can I expect?
2) Is the collector a slip-fit design or does it use a flange?
EDIT: I should clarify that by "clearance" I do not mean ground clearance. Thinking more about engine bay clearances...
Maybe he will chime in here....
Hopfully a K member will help with room.
Based on the available tubular K-member designs I've seen to date, they are not an option for me so I'm going to have to make it work with stock unless something else makes its way to market (LG maybe
). Based on the available tubular K-member designs I've seen to date, they are not an option for me so I'm going to have to make it work with stock unless something else makes its way to market (LG maybe
).Yea that is the thing, he left for Mexico today for a Vacation.... If he calls in to check on things I will ask.
now the driver side is a slight nightmare untill you jack the engine up and cut the k member , wich is weird because the drivers side didnt really need much clearance after it was in and bolted up just needed the clearance to get it in there. i only had to cut both sides of the k member and have the oil filter off before installing them, the engine was also unbolted and jacked up about 3 inches above the mounts.
they are slip fit.
i have pictures also - dont have one of the passenger side after it was cut yet though , maybe later i'll put that up if anyone wants to see.
