View Poll Results: what's your choice will be ?
True Duals
209
65.11%
ORY & Catback
112
34.89%
Voters: 321. You may not vote on this poll
poll: true duals VS Ypipe & cat-back?.....
Old Feb 26, 2006 | 10:39 PM
  #121
blkZ28spt's Avatar
Originally Posted by SouthFL.02.SS
Hello loud and fumes!
Loud, yes.
Fumes, probably on occassion. I don't get the smell of fumes very often. If the breeze is just right while I am stopped I do, but other than that you can't smell a darn thing.
Just don't run the care for very long inside the garage.
Old Feb 26, 2006 | 10:46 PM
  #122
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Originally Posted by blkZ28spt
Loud, yes.
What's funny was that I read 00TA's description about cruising in front of the popo station and how quiet the car is (thinking wow, it must be quiet), then the clincher... I want to put an MS3 in it! It will make a helluva difference.
Old Feb 28, 2006 | 12:18 PM
  #123
RawDawg's Avatar
Just make sure you have headers. I didn't and I had a custom dual exhaust put in and everytime I came to any sort of dip in the road.........scrraaaaaaape! I'm getting headers next month and a custom Y pipe to take care of the clearance issue but other than that duals have been great!!
Old Feb 28, 2006 | 04:33 PM
  #124
00TAProject's Avatar
Unfortunately with the new cam come along a lil quieter TD Exhaust.....Stayin Duals, just a small adjustment, and different mufflers other than bullets....BUT still staying with TD's....:USA:
Old Mar 1, 2006 | 02:12 AM
  #125
SloLS1's Avatar
If I go with a true dual setup over the axle, what kind of clearance issues will I be facing? My car is lowered 1.25".
Old Mar 1, 2006 | 02:34 AM
  #126
rbobryk20's Avatar
THis video leaves me drooling! love the sound and i can def. tell its TD's but i don't think it sounds redneck whatsoever.
Old Mar 1, 2006 | 11:15 AM
  #127
blkZ28spt's Avatar
Assuming you have a 3" Y-pipe right now a properly fit and tucked away dual setup won't cost you anything. The difference will likely be that intead of one low point you will have three or so points around the same height. That was my experience, at least.
Lowering these cars with performance in mind just doesn't work well. You lose space for things like exhaust, higher capacity transmission pans and subframe connectors. It also changes the geometry of the suspension and can screw your 60' times up.
Old Mar 1, 2006 | 11:22 AM
  #128
300bhp/ton's Avatar
+1 on the lowering issue. While the ride height (gap from top of tyre to wheel arch) may look big the gound clearance (hight of car from the ground) is pretty low already and really doesn't need lowering for any reason except looks.
Old Mar 1, 2006 | 11:48 AM
  #129
97blkz's Avatar
Ughh w/o emissions is there a need for this Q?
Old Mar 1, 2006 | 08:31 PM
  #130
SilverM6SS's Avatar
Default Duals
Wild 348, Pacestters, TSP 3" duals with bullets. The only negative is the ground clearance, and a little hassle, from local PD. I do have a ORY and a catback still, just in case I need to quite it down, for some reason, ie emissions. I personally think it sounds better than any y pipe set up that I have heard.
Old Mar 19, 2006 | 10:58 PM
  #131
Ferocity02's Avatar
I have had two dual set-ups and neither are as nice as what I have now, LT's with dual cutouts, cats, and Flowmaster catback. The duals sounded very nice, refined, but the complete lack of ground clearance created problems. Also, they are very easy for the cops to see. My current set-up is more CA friendly.
Old Mar 28, 2006 | 06:25 PM
  #132
nomadnate's Avatar
[QUOTE=300bhp/ton][b]
Duals are also an issue as there are few off the shelf kits, and most that are available dump before the axel, so they are VERY loud.
[QUOTE]
and what is so bad about that
Old Apr 3, 2006 | 04:28 PM
  #133
JDP's Avatar
JDP
some of us like to our monsoon stereo systems that gm gave us
Old Apr 4, 2006 | 05:59 PM
  #134
Formula_X's Avatar
How bad is the ground clearance with the TSP Rumbler X? Can you go over speed bumps without a problem? (my car is not lowered)
Old Apr 4, 2006 | 08:44 PM
  #135
brad8266's Avatar
I dont have clearence issues as long as I dont go haulin *** over speedbumps.
Old Apr 6, 2006 | 10:24 AM
  #136
pewterta's Avatar
[QUOTE=nomadnate][QUOTE=300bhp/ton][b]
I agree nomadnate...this guy obviosly has no idea what hes talkin about
Old Apr 6, 2006 | 11:28 AM
  #137
300bhp/ton's Avatar
[QUOTE=pewterta][QUOTE=nomadnate]
Originally Posted by 300bhp/ton
[b]
Not everyone wants a loud exhaust (hence not all aftermarket exhausts are loud ).
Also ground clearance can be an issue, and venting the exhuast under the car is not preferable to everyone (and is illegal in some places).
Also if you're so bright try fitting one of these:
And then buy an off the shelf dual kit and see if it fits - it won't!
Old Apr 6, 2006 | 11:40 AM
  #138
rufretic's Avatar
[QUOTE=300bhp/ton][QUOTE=pewterta]
Or you can make it your self like I did and it will fit.
The duals gave me more power than a y-pipe with open cutout and sounds 10 times better. Mine is loud but if you don't like loud you can put on different mufflers, mine are sweet thunders.
Old Apr 6, 2006 | 03:58 PM
  #139
300bhp/ton's Avatar
[QUOTE=rufretic][QUOTE=300bhp/ton]
I agree custom is generally the way to go with duals, but this was being directed at off the shelf kits. Personally I have no problem with any setup, as people can run what they choose and I'll spend my money and run what I want. But giving info over so that people can make this decision was my aim.
Cool pics in your sig BTW
Old Apr 6, 2006 | 07:00 PM
  #140
rufretic's Avatar
[QUOTE=300bhp/ton][QUOTE=rufretic]
Thanks,
I wasn't saying you were wrong, just giving another opinion and saying fitment can be worked around if someone really wants them.
