poll: true duals VS Ypipe & cat-back?.....
It is a comparisson, but I would not call it a good comparisson. At least not truly apples to apples IMO.
I would think this is due to one of two reasons. First off lots of people put the cutouts before the mid pipe, thus totally removing the scavenging that can be achieved with it. The other thing it the exhaust pressure wave, the cutouts may have been having a negative affect on it.
I can make a Y-pipe system work as well as any true dual with less clearance problems for either drag applicaiton or road race. System design of individual components will have a greater determining role in net HP than being a Y or true dual configuration alone.
I agree. Especially with some of the Y-pipes out there. I think the Flowmaster collector looks and flows the best.
I'm lookin to try a X-setup. What mufflers would you use for max HP and not losing any TQ too?
And personally, I hate spending money on parts that only boast of "zero loss".
Right now my car is stock but I have a set of Kooks LT's with a catted y-pipe going on soon. Presently, I'm leaning toward keeping the stock catback and just installing a cutout. Or I might spring for a Hooker catback.
I just don't want to deal with some of the drawbacks of dual systems. In particular, fitment and clearance can be an issue, as well as cost, and/or the high noise level.
JM2C
I will build my own mandrel bent 3" Y pipe using a Flowmaster dual 3" in single 4" out into a 4" pipe with 4" cutout before it goes over the axle and then reduce it to 3" of the cutout and over the axle with whatever catback.
So basicly just replace the I pipe of a catback with a 4" piece and cutout.
A single 3" pipe is nowhere enough for one of these engines. Ive had 5 exhaust on my car now duals and catbacks. The seat of pants aint even close to the same. My trap speeds were not even close to the sme either.
Some things to look at:
Flow capacity-
3.0" diameter pipe = 3.14159 * 1.5 * 1.5 = 7.0685 sq in
3.5" diameter pipe = 3.14159 * 1.75 * 1.75 = 9.6211 sq in
4.0" diameter pipe = 3.14159 * 2 * 2 = 12.5663 sq in
Remember now too that exhaust flows in pulses and not a continuous stream. The addition of both banks of 3" pipes does NOT mean you need to suddenly flow DOUBLE what 3" pipes flow. In effect you need to still only manage each pulse firing with consideration that you may have occasional double pulses passing through the collector (this is a result of still only one cylinder firing at a time but unequal length banks in your y-pipe.) A single pulse passing through a 7.0 sq in cross section into a 12.5sq in cross section will dramitaclly slow down and cool off as well (bad for velocity.)
A calculated dual 3" y into a 3.5" I and a cutout will net you the same power as the sytem you describe and will pass through your g load brace and wont bang your floorboard like the 4". In just about any instance i can think of the power you are making wiht your car does not justify 4" exhaust.
. I only argue that a Y-pipe can make big power.
