Torque of header bolts?
Old Feb 26, 2006 | 02:30 PM
98camaroLS1M6's Avatar
Default Torque of header bolts?
How much should header bolts be torqued down to?
Old Feb 26, 2006 | 02:43 PM
ShevrolayZ28's Avatar
I wouldn't use a torque wrench. Just go easy on them with a 3/8" drive rachet or box wrench. If it leaks snug them up some more.
I'll look it up for you anyways....hold on.
Old Feb 26, 2006 | 02:46 PM
jrp's Avatar
jrp
SN95 Director
18ft-lbs
2K2WS6TA's Avatar
11ftlbs 1st run, then tighten to 18ftlbs
Old Feb 26, 2006 | 02:49 PM
2001NBMZ28's Avatar
Stock is 11 lb ft first pass, starting with the center bolts and alternating outward, then a final pass, same sequence to 18 lb ft.
Old Feb 26, 2006 | 02:51 PM
The GM service manual for the 2002 5.7L lists a first pass tightening spec of 11 lb/ft, and final pass spec of 18 lb/ft. That is not a lot of force. Be careful.
Edit: I'm too slow
Old Feb 26, 2006 | 02:58 PM
2001NBMZ28's Avatar
Originally Posted by ShevrolayZ28
Edit: I'm too slow
LOL Same here, was answered by the time I looked it up, posted and hit submit.
Old Feb 26, 2006 | 05:35 PM
slowpoke96z28's Avatar
you are using the stock GM gaskets, right?
 Michael S. Palmer
Old Feb 26, 2006 | 05:44 PM
davered00ss's Avatar
Moderator
Just did a set of Kooks today. 18 ftlbs.
Old Feb 26, 2006 | 05:45 PM
Moderator
& heads too
Old Feb 26, 2006 | 05:51 PM
NexGen's Avatar
Originally Posted by davered00ss
& heads too
You baller......
Old Feb 26, 2006 | 05:59 PM
Moderator
Spent all weekend on a friends car.
Old Feb 26, 2006 | 06:05 PM
JonB's Avatar
Does a torque wrench actually fit in there. I can see getting maybe the first 1 or 2 on each side but what about the rest of them. Just curious since I will be doing headers soon.
