98-99 y-pipe problem / 00-02 work?
Old Feb 15, 2006 | 07:57 PM
MySickCamarodotCom's Avatar
Question 98-99 y-pipe problem / 00-02 work?
i own a red 1998 zs8 cam. now, i ordered the corsa cam/fire exhaust w/ 3.5 tips about month ago....installed and are fine. on feb 11 i ordered a 98-99 ls1 f-body y-pipe for the car. the people at slp sent me the 00-02 ls1 f-body y-pipe. will this work? or do i need to go thru all the b.s. to send the y-pipe back and get the 98-99? any help would be appreciated....
Old Feb 15, 2006 | 08:52 PM
WILWAXU's Avatar
Nope, different setup.
Old Feb 15, 2006 | 11:12 PM
magius231's Avatar
whats different between the 98-99 and 01-02 Y-pipes?
Old Feb 15, 2006 | 11:16 PM
00transamnh's Avatar
i beleive if it is an ory you are all set
i think the only diff would be the possition of the cats if its a catted y but dont hold me to that
Old Feb 16, 2006 | 04:03 PM
i called the dealer and he told me that the are different on the drivers side(i believe). but the manufacturer said they started making them so they can work on either a 98 to 02. but it requires welding and cutting the pipes. which is totally the opposite of why i ordered them. ya know. i told them i wanted them for a 98 camaro. and they tell me that the 00-02 will work along with the aid of a torch and welder......those common bastards. so i sending it back tomorrow and told them to send me what i ordered which is also what they advertised.
Old Feb 16, 2006 | 05:20 PM
Bad30th's Avatar
Here's a post that shows the differences between the years :
https://ls1tech.com/forums/showpost....7&postcount=12
Cheers,
Rob (Bad30th)
Old Feb 16, 2006 | 08:03 PM
Z28camaroLS1's Avatar
My understanding is that even if they had sent you the 98-99 Y-pipe you still had to weld and cut pipes short before the passenger side's cat. I think that's the reason they said the 00-02 pipe will also fit cause you have to cut / weld pipes anyway.
Old Feb 26, 2006 | 06:06 PM
thanks everyone i got it all straighten out. i decided to send it back and to have them send me the MAC offroad y-pipe (full, to deleted the cats). She sounds sexy....thanks again.
