Descreening stock MAF?
Just leave it unless you plan to spray a dry shot.I had mine descreened and had issues,.So I went back to a stock screened maf.
https://ls1tech.com/forums/showthrea...Descreened+maf
The only reason I say its not worth it is because if you do have problems then you have to buy another maf.You cant just put the screen back in no matter how careful you take it out because it will skew the readings.So unless you are going to spray a dry shot or have tuning done after its removed I wouldnt do it.But then again I am someone that had issues with a descreened maf.Even with tuning I had issues.
talks about descreening. Indicates it is a good idea if there are not curves or bends in the air intake track in front of the MAF.
Rest of article is good reading as well.
BOSS APPROVED!
