pacesetter y bang?
Old Mar 1, 2006 | 06:08 PM
Charlie@LsXperts's Avatar
Default pacesetter y bang?
i just got my y pipe pacesetter in yesterday and i noticed its crushed, does that mean that the pacesetter y doesnt bang?
Old Mar 1, 2006 | 08:00 PM
CW00BlackTA's Avatar
It's "crushed" to give it more clearance--which should help prevent banging.
Old Mar 1, 2006 | 08:09 PM
Ehatcher's Avatar
But with my experiences .... it still banged pretty badly .
Old Mar 2, 2006 | 01:12 AM
Juiced2000SS's Avatar
It'll bang, get a hanger from Thunder Racing $40.
Old Mar 2, 2006 | 07:24 AM
LiquidSword's Avatar
I suggest spacing it with some 2X4" wood and tightening really good. (use an impact if possible). I have the Mufflex hanger and all that does is move the location of the bang. I only feel it when turning mainly, but it's still there. Doesnt really bother me untill I turn while giving it gas.
Save the $40 and try that first.
Old Mar 2, 2006 | 08:52 AM
MannyZ28's Avatar
I have the mufflex hanger, but I also used the 2x4 method to keep my Y from banging.
This right here is the area that will rub....
As you can see, the first "fix" was hood insulation and a heater hose wrapped around the rubbing point with two band clamps. That didn't work too well.
The we put the mufflex hanger on there...
That wasn't a good fix at first because of where we mounted it. Also, the clamp of the hanger kept slipping and it landed up in the position you see above with the rubber hitting the Y pipe and starting to melt.
I don't have a picture of the solution, but basically, to mount the Mufflex hanger in the position where it would do the most good, we had to cut it reverse it, and re-weld it, this is coz my rear O2 bung is located where the hanger is supposed to go. Once we had it in the right postion, we tack welded it in place on the Y pipe so it wouldn't slip. I also used stainless steel zipties, yes they make those, to keep the two rubber together. Finally we used a 2x4 to crush my Y pipe just a bit more.
Haven't had any problems since.
I'll take some pics of this on saturday, that will explain it much better.
Manny
