should I get rid of the AIR and EGR?
Old Mar 27, 2006 | 11:30 AM
Juiced2000SS's Avatar
Originally Posted by Superman09
So can someone tell me exactly all i need to buy and is it 100% certain i'll throw a code or no?
Buy the kit from Speed Inc. Comes with EVERYTHING you need. You WILL throw a code, live with it or get it deleted.
Old Mar 27, 2006 | 12:20 PM
SMSFRC99's Avatar
definitely will throw a code
Old Mar 27, 2006 | 12:39 PM
dnm12's Avatar
sorry not to steal the tread but if you have a 98 i assume its best to leave the EGR and AIR untill you get a cam with enough overlap it takes care of that? TIA
Old Mar 27, 2006 | 03:11 PM
s1ck s0n's Avatar
can the obdII scanner at autozone delete the code or do i need some other kind of tuner?
Old Mar 27, 2006 | 04:05 PM
dnm12's Avatar
tuner i am assuming but you have a 98 like me and keeping the EGR is probably better i am assuming but waiting for someone to answer my above question basically can you remove the AIR and EGR without an huge overlapping cam
Old Mar 27, 2006 | 06:05 PM
Blacker's Avatar
The scanner at Autozone is just a scanner. You will need tuning software like HP Tuners/EFILive or a tuner shop to disable the DTC's for EGR.
Old Mar 27, 2006 | 06:08 PM
Blacker's Avatar
I removed the EGR before I replaced the stock cam and had no issues with performance. The AIR was removed after the cam since I upgraded the Hooker LT's to QTP Race Headers.
Old Mar 27, 2006 | 09:17 PM
s1ck s0n's Avatar
well i learned my friend has an obdII scanner thing that can delete codes, so that should work right? i dont know why it would have to be ls1 specific.
