Exhaust sounds like sheeeetttt!!!
Old Mar 6, 2006 | 01:15 PM
1fastz28nx's Avatar
Default Exhaust sounds like sheeeetttt!!!
Just did a big H/C swap adn many boltons, which included LT's and 3"ORY. I already had teh TSP Rumbler catback exhaust on my car. Well it sounds bad as hell at idle and WOT, but anything in between it "slaps" and pretty much sounds like ****. Did this happen to anyone else? Any recommends?????????
Old Mar 6, 2006 | 01:29 PM
iamsickofitall's Avatar
i feel pretty much the same way about my exhaust after h/c swap...and i have cats to boot - i'm going to quiet the exhaust down as much as possible and go with an slp dual/dual
Old Mar 6, 2006 | 01:44 PM
1fastz28nx's Avatar
loud is fine with me, I just dont want it to sound like ****. i was thinking maybe tsp true dual, but ive heard it vibrates the **** out of everything. any other suggestions.
Old Mar 6, 2006 | 01:49 PM
02SS:ZEUS's Avatar
Check this out....
https://ls1tech.com/forums/generation-iii-external-engine/462478-pics-completed-true-dual-over-axle-exhaust-w-edelbrock-lt-s.html
there is a video also.
Old Mar 6, 2006 | 01:55 PM
~JOSHUA's Avatar
When you say "slap" do you mean "blats it's *** off" if you hit the gas under a load? It "blats" the more you lug the gear? If so that's called *rasp*, and I'd expect it form a set-up like yours. That's just the way it goes.
You only way to rid that is to get a quieter muffler like a Corsa or SLP DD.
That's why I left my DD in place after I did the cam, headers and off-raod y. If you had cats it would remedy the issue, but that would choke the cam.
My SLP sounds really good, and gets beastly at wide open throttle. It still has a mature sound to it. I guy told me just yesterday that he hasn't heard an exhaust note like that since 1972!
Old Mar 6, 2006 | 01:56 PM
Redneck Z's Avatar
You could throw some cats in there and put a Borla XR-1 in the I-pipe. We just put the hooker longtubes w/ o/r y-pipe on a friends car with the dynomouth, and it's exactly as you've described it. The mid range has a very annoying rasp.
Old Mar 6, 2006 | 05:33 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Yeah cats will help out big time with the rasp...I would try that first.
Old Mar 6, 2006 | 10:34 PM
camaross305's Avatar
get a tsp true dual kit and run them out back under the axle like i did. sounds so sick no vibrations and sounds sweet.
Old Mar 6, 2006 | 10:38 PM
TheBlurLS1's Avatar
That's what she said...
^^^ I'm with him! ^^^
Check the link to my exhaust setup in my sig, tons of pics, videos, and info on there. The problem is your catback. The TSP rumbler system is almost identical to an SLP Loudmouth.
LT's + ORY + Loudmouth = one of the most hated LS1 sounds ever.
Old Mar 6, 2006 | 10:55 PM
ls2 bait's Avatar
thats a big negative on the corsa. mine is damn near as loud and rasy as my buddys loudmouth with the same headers. ill be searching to remedy this myself.
Old Mar 7, 2006 | 02:13 AM
TransAm6383's Avatar
my friend got the rasp out of his car with long tubes and LM by putting a bullet muffler in there..helped ALOT.took out the rasp at low rpms
Old Mar 7, 2006 | 02:28 AM
Redneck Z's Avatar
It must have been REALLY raspy before! Like I posted above, my friend has the same setup. Longtubes, o/r Y and dynomax bullet, and it's EXTREMELY raspy! IMO, you'll need more than a bullet muffler to calm the rasp.
Old Mar 7, 2006 | 03:21 AM
Benjamin Russick's Avatar
Borla XR-1 in place of the resonator/muffler. Makes a bigger difference than you would think...
Old Mar 7, 2006 | 03:28 AM
cantdrv65's Avatar
Post
I think a true dual setup with some type of resonator/muffler will get rid of all the rasp. my stainless work 3" duals sounds nascar style. My former camaro's single/y-pipe hooker catback setup always had a little rasp until i put in cats.
Old Mar 7, 2006 | 04:10 AM
Redneck Z's Avatar
Was that in regards to my post? I was talking about the dynomax bullet. There is a big difference between the Borla and dynomax.
Old Mar 7, 2006 | 05:02 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Just TD that shyt. IMO, I think that I deleted most of the crappy notes from my exhaust by going down to a 2.5 flanged out the back setup.
Old Mar 7, 2006 | 08:43 AM
jmm98LS1's Avatar
The cause of rasp really isn't which catback or muffler you have. It's the y-pipe that causes the rasp. Some mufflers/catbacks cover it up better than others. The exhaust "slams" into each other at a certain rpm when in merges into the i-pipe. The only way to actually get rid of it (not cover it up) is to switch to a well designed y-merge collector (flowmaster y-merge for example) or switch to a true dual setup. My old setup (macs/ory/cutout) was the King Bastard of all rasp. Switching over to lt's/x-pipe/1 chamber flowmasters has eliminated any hint of the crappy sounds I used to have.
Old Mar 7, 2006 | 10:19 AM
Charlie@LsXperts's Avatar
i also have tsp rumbler with ory and longtubes and i dont like it half the time but the other time i do so i dont really know what to do.... i really dont care i guess ill be about half happy
Old Mar 7, 2006 | 11:12 AM
hourang's Avatar
i got sick of the rasp so i cut the catback off, put a dynomax bullet and dumped it before the axle, i have no rasp, sounds beautiful!
Old Mar 7, 2006 | 05:46 PM
ls2 bait's Avatar
gonna have to disagree. i have the flowmaster merge on my lt, ory, corsa and its prob one of the raspiest i ever heard next to a loudmouth.
