Help: I installed SLP Long Tubes and y-pipe is banging the floor board.
Old May 17, 2002 | 08:55 PM
ldickson's Avatar
Default Help: I installed SLP Long Tubes and y-pipe is banging the floor board.
I Put SLP long tubes on about two weeks ago and every sense then the y-pipe bangs at wide open throttle and I can.t find where its banging at.Have anybody had this problem before?? and what did you do about it.
Old May 17, 2002 | 09:09 PM
Supertrapped's Avatar
Speed freak
Default Re: Help: I installed SLP Long Tubes and y-pipe is banging the floor board.
Might wanna check your factory DS plate. Mine banged for a day. I took the plate off and crimped it in the middle so it hangs a little lower. Hasn't banged since.
But...I changed to a x-pipe system just a couple of days ago and just went ahead and removed the plate.
Hope that helps
Old May 17, 2002 | 09:21 PM
99 WS6's Avatar
Could be back at the intermediate pipe, if the headers aren't angled down far enough, the pipe can hit. I remember someone posting about it before. To change the angle, loosen the header bolts and rotate the headers around the center bolt to line them up.
Old May 18, 2002 | 02:16 AM
felton316's Avatar
Mine banged on the driver's side of the Y pipe. I loosened everything then inserted a 2X4 then retightened, then removed the board. I'm also currently using a torque strap which helps alot!
