pros and cons of descreening and porting my MAF
Old May 19, 2002 | 11:21 AM
spdracer's Avatar
Default pros and cons of descreening and porting my MAF
i was looking at installuniversity the other day and was wanting to port and descreen my MAF. has anybody outhere done this and if so is it worth it or is it better to go and buy MAF ends from a vender.
thanks
d
Old May 19, 2002 | 02:42 PM
WILWAXU's Avatar
Default Re: pros and cons of descreening and porting my MAF
Cheapest... port your own.
If you want to keep the stockers for back up.. buy aftermarket.
I have had great results using port MAF ends.
Old May 19, 2002 | 07:36 PM
Supertrapped's Avatar
Speed freak
Pros....adds timing and leans A/F ratio a little. People usually see between 5-10hp out of this mod.
Cons....decreased line pressure in tranny under WOT.
I've got ported MAF ends. I could tell a noticeable difference <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old May 19, 2002 | 08:38 PM
Ragtop 99's Avatar
I've seen them work well, but I'll give you the cons... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
1) As noted above, it can reduce the A4's line pressure, but it actually impacts part throttle pressure as well and can lead to glazed clutches.
2) It is really a crutch to solve tuning issues (slightly rich, conservative timing) that could properly be handled through LS1 Edit. If you will be a heavy mod'er, you'll eventually want/need Edit, so buy it now rather than putting money into a piecemeal approach such as MAF ends/HPP3/O2 simms etc.
