what to plug in the lid??
Old Jun 13, 2006 | 07:42 AM
00454sscamaro's Avatar
hmm fiber glass might work.. or a small peice of plexy glass and plasitc weld.. you can use damn near anything that isnt going to leak. a peice of threaded aluminum with 2 nuts and a washer to seal it. take the seal that was in there and go to a hardware store , thats what i did for my egr .. cake i found a "toilet plug" fit perfects after a razor blade modification to it.
Old Jun 13, 2006 | 05:29 PM
Justin00SS's Avatar
I got an explandable freeze plug from the auto pats place for about 2 bucks.
Old Jun 21, 2007 | 09:53 AM
Camario's Avatar
I went to Menards and bought a "Knock Out Seal" that is labeled 3/4" The subtext says its "For closing exposed Holes in an Outlet Box or Metal Enclosure" and its found in the Electrical Department. All it needs is to be painted and it fits perfectly!
I have two more (lost 1 somehow) so if anybody needs one i'll put it in an envelope and mail it off, just pm me!
Old Jun 21, 2007 | 10:06 AM
SLPSS01's Avatar
www.caplugs.com
Part number BPF-1 1/8-6. On the home page you can click to order free samples.
I need to get the pics back up on my server but I can almost gurantee this is the same exact piece SLP uses.
I have a business account with Caplugs if enough people need these I can order some.
http://www.caplugs.com/catalog/starp...command=search
Old Jun 21, 2007 | 08:09 PM
Fb0dy0nly's Avatar
I am just going to take my lid to home depot first and see if I can find something to fit, if not, then I will try the plenty autoparts stores around the city and IF that doesnt work, well my dad is a pipe-fitter for GM, I am sure he can find something.....
if you didnt care how it looked, you could just gorilla glue a piece of black plastic over the hole.....
Old Jun 21, 2007 | 08:53 PM
LS1_Disciple's Avatar
I used a PVC pipe plug from Lowe's/HD. Painted the head flat black so it matched the lid. Just measure the ID of the hole and head for Lowe's.
Old Jun 21, 2007 | 09:18 PM
ArchetypeZ28's Avatar
Former Vendor - No longer Vendor
i picked up a tire patch kit from wal-mart for $2. used the big patch to seal the air tube and the smalled patches to seal my old n2o holes. Been holding for over 2 years now.
Old Jun 22, 2007 | 12:24 AM
Ripper415's Avatar
Originally Posted by mcamp001
www.caplugs.com get the 1 3/32 plug, fits perfect, and it's free!
Originally Posted by SLPSS01
www.caplugs.com
so which one is the right one?
Old Jun 22, 2007 | 03:32 AM
BobDoLe's Avatar
Originally Posted by Transgression
ok i need to know what to plug in my slp lid(the AIR tube hole)since i'm deleting my air system this friday along with long tube install. please help!
thanx
how bout a dry shot nozzle
Old Jun 22, 2007 | 08:23 AM
sixvi6-camaro's Avatar
I did this on mine.. like it a ton better than the other options.
https://ls1tech.com/forums/showpost....1&postcount=17
Its a chrysler master cylinder plug available at just about any auto parts store in the Help section.
Old Jun 22, 2007 | 02:30 PM
Phlip00WS6's Avatar
Same thing I did, picked it up at autozone. It was a little loose in mine so I just glued it on.
Old Jun 22, 2007 | 11:25 PM
  #32
SLPSS01's Avatar
Here is the Caplugs part installed:
Part number BPF-1 1/8-6 is the one pictured. I'm the one who originally suggested this part, I know a few others here have used this one as well.
This is 1.125" diameter, the hole diameter in my SLP lid is the same so it's obviously a tight fit but seals up nicely. It's a flush mount.
The other part number listed above is 1.032", slightly smaller than the hole, it may fit a bit loose ? I'm not sure I haven't tried it.
Old Jun 23, 2007 | 07:40 AM
  #33
gillbot's Avatar
Originally Posted by Justin00SS
Go to home depot or lowes and brainstorm man.
There are so many plugs in the damn place. Hell try the adult toy store. I've been told that place is full of plugs.
I used a cabinet door hole plug from lowes that was $0.89 and a rubber band for a seal. There are pics around here somewhere of it.
Old Jun 23, 2007 | 06:37 PM
  #34
Andros's Avatar
Why not try black tape? It worked for me for a while until I switched to the volant cai.
Old Jun 23, 2007 | 07:03 PM
  #35
S1LV3R's Avatar
Originally Posted by JustAnIlluzion
home depot? napa? if you have to ask maybe you should find a new hobby?
haha...
Originally Posted by davered00ss
I tried those. No luck.
Maybee I don't know what I'm doing
Old Jun 8, 2009 | 10:47 AM
  #36
5301113's Avatar
saving this
