Stuck Crank Bolt Help?????
Go with a High quality 1/2 braker bar and good 6 point socket and cheater bar and you should be able to bust it loose.
" to do is heat the crank up so it expands, and relieves the pressure on the bolt.For example have you ever heard of the pulley in the oven trick. You put your underdrive pulley in the oven @ 210 or so for an hour, it expands the pulley and you can usually slip it right on the crank (didn't quite work for me). SAME CONCEPT.
If you heat that bolt up too much your going to have problems!!!
Just my thoughts!
His bolt broke off on the way out. Sucked the pulley on with a torque wrench, on the stock bolt, started backing it out and the torque wrench popped, like it was getting tighter. Then it just snapped off. We drilled and drilled and broke drill bits and easy outs. Finally (after i left), they started drilling bigger and bigger untill the threads of the bolt started to come apart.
If you've got a buddy at a machine shop, they might be able to help. Worst comes to worse, you take the motor out and bring that bitch somewhere.
