Lubrication Specs Important????
Also, do you think its time i change out the plug and wires and if so, whats the best combination out there, (MSD wires w/ NGK plugs?) <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
I'm using the MSD wires. If you don't wan't to spend the money on the wires you could get a meter and check the resistance on the wires-see if any are way high- if not you could stick with stock. Matter of preference,I don't believe the stock wires are that bad.
