Just a couple of header questions
What do stepped primaries do and why would they be desireable?
What is a good primary tube length?
thanks
Stepped headers increase flow by using a larger primary downstream, but keep the velocity up by using a smaller tube right at the port, this also helps reduce reversion. Not needed if you're doing a mild buildup, unported heads, etc. This is helpful in giving more flow, but keeping ok torque in the mid-range (more velocity generally equals more torque).
Most of the popular long tubes have the longest primaries at 30-32" lengths. Some of the header length calculators will give you numbers like 36 should be the best. I dont know what kind of room you are going to have under that Vette, probably a lot though since it would accept a factory big block.
J.
edit - here is a pic of a stepped header.
<img src="http://www.hedman.com/images/torkhdr-closeup.jpg" alt=" - " />
I guess since you are going to have to cut the primaries at the flange it wouldn't be much more trouble to step it down to 1.75 right there are the port, but I'd try to keep the stock bend, as a crimp/crush bend at that part of a header might really hinder performance.
J.
<small>[ May 27, 2002, 08:48 AM: Message edited by: Crazyquik ]</small>
