GM Injector Options
Old May 29, 2002 | 07:50 AM
Sparky's Avatar
Default GM Injector Options
Does anyone know what other GM vehicles have injectors (higher flow) that would fit an LS1? Maybe the Vortec truck engines?? Is there any easy way to find out the specs?
Mark
Old May 29, 2002 | 08:47 AM
MIGHTYMOUSE's Avatar
Default Re: GM Injector Options
the grand prix gtp's have like 30#'s i THINK, but any ford (bosch) injector will work with your computer such as 36#'s and 42# svo injectors.
Old May 29, 2002 | 01:58 PM
Ragtop 99's Avatar
As I recall, The GTP's work out to around 38lbs at our fuel pressure.
Old May 29, 2002 | 03:45 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I am running Pontiac GTP injectors and they are pretty darn big, but the pcm can be programmed to work. They work out to like 39.5 lb injectors.
ARE 422ci
Old May 29, 2002 | 07:27 PM
White_Hawk's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong>I am running Pontiac GTP injectors and they are pretty darn </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Do you have the GM part number for those handy? I would be much appreciative as I need a set very soon.
Geoff
'02 Hawk #646 No mods yet
Old May 30, 2002 | 09:53 AM
Sparky's Avatar
Thanks guys, 38lbs should work out just right!
Mark
Old May 30, 2002 | 02:00 PM
y2khawk's Avatar
PN#24508208
<img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jun 3, 2002 | 05:07 PM
White_Hawk's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by y2khawk:
<strong>PN#24508208
<img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks for the info - I'm a little slow in reading threads sometime...
-Geoff
Old Jun 3, 2002 | 06:00 PM
and the 'ford' injectors go way past that at 'our' fuel pressure. what output are you looking for?
Old Jun 4, 2002 | 08:43 PM
White_Hawk's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MIGHTYMOUSE:
<strong>and the 'ford' injectors go way past that at 'our' fuel pressure. what output are you looking for?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Daaayummm! I got the price on those GTP injectors and they are $51 each dealer cost and $100 retail! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> Does anyone have a suggestion on where to get some injectors? I am looking to run a max of 450 at the wheels. Initially, I am going to be running a 6 lb powerdyne with no FMU. I am going to set up a good fuel system and get it programmed or do it myself (still undecided).
Thanks for the info.
Geoff
'02 Hawk #646
Old Jun 5, 2002 | 12:03 AM
cablebandit's Avatar
get on ebay and buy some svo 42# form "pedaltometal" generally go for about 285.00 a set of 8
Old Jun 6, 2002 | 08:04 AM
Slart's Avatar
I believe the Ford '86 TBI injectors are 72 lbs@39 PSI which would make them flow 88 lbs/hr in our cars.
Old Jun 6, 2002 | 09:49 AM
Ragtop 99's Avatar
try this guy:
valvegod@aol.com
GTP injectors should be less than $250 for a set, low or no mileage.
Old Jun 6, 2002 | 10:42 AM
White_Hawk's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ragtop 99:
<strong>try this guy:
valvegod@aol.com
GTP injectors should be less than $250 for a set, low or no mileage.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks for the tip, I forgot about him! If his profile is right, he is about ten miles from my house, too. Thanks!
-Geoff
Old Jun 6, 2002 | 06:02 PM
NastySSoo's Avatar
Are our stock injectors adequate for most H/C cars of stock displacement?With no boost or NOS ?
Old Jun 7, 2002 | 06:46 AM
Sparky's Avatar
Nasty, on my H/C '99 (same size injectors as an '00) I was running at 103% duty cycle at the top end of WOT. On a strong H/C package for our years, it's close I guess.
Mark
Old Jun 7, 2002 | 08:39 AM
NastySSoo's Avatar
Thanks, I quess Ill leave well enough alone for now.
Old Jun 7, 2002 | 08:43 AM
Ragtop 99's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by NastySS00:
<strong>Are our stock injectors adequate for most H/C cars of stock displacement?With no boost or NOS ?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The 1999 & 2000 cars have smaller injectors, which makes them marginal on a high reving H&C package. 98 & 01s have a little bigger injector and are adequate.
