band clamp question
Old Mar 10, 2006 | 09:48 AM
magius231's Avatar
Default band clamp question
ok I've never used a band clamp before, so I'm not sure if this is the right way to do this...
The headers I am using are 3" collectors, the Y-pipe is 3" as well, and theres no overlap section its all butted together. Will a band clamp seal this? Is there any way to seal this other than welding, since I want to be able to remove it when necessary?
Thanks in advance, just trying to get ready for this weekends header install...
Old Mar 10, 2006 | 10:00 AM
TUFAS4U's Avatar
which headers and y-pipe? if its slip fit the y should be flared out to slip over the collectors, the band clamp actually pinches the two together for a tight seal and you wont damage the pipes for easy removal.
Old Mar 10, 2006 | 10:13 AM
ApacheDrill's Avatar
Well "one time at band clamp"...
Sorry wrong thread read that wrong....
Old Mar 10, 2006 | 10:32 AM
magius231's Avatar
hooker headers and Y-pipe, but its NOT flared as its a used setup that was welded then cut. I was hoping there was some way to connect them without welding...
Old Mar 10, 2006 | 10:51 AM
TUFAS4U's Avatar
sounds fubar
Old Mar 10, 2006 | 01:02 PM
magius231's Avatar
I may just weld an extension on the Y-pipe that will go over the collector, then band clamp that down...that might work if I can find the extension that will fit...
Old Mar 10, 2006 | 01:32 PM
WhiteRhino's Avatar
You could always put reducer flanges on the headers and y-pipe.Something like this.
http://store.summitracing.com/partde...1&autoview=sku
Old Mar 10, 2006 | 05:14 PM
ashade98's Avatar
Summit sells band clamps without the lap joint for slip fit. They are called butt joint. If you can get the headers and Y to meet all the way up, maybe a butt joint band clamp will hold 'em?
Old Mar 10, 2006 | 06:02 PM
Redneck Z's Avatar
Haha....you said butt joint!
Old Mar 10, 2006 | 08:36 PM
Ping King's Avatar
i would pull the y pipe...have a 3 inch od-od adapter welded on...then band clamp that.
Or just say f it and do some v band clamps
Old Mar 11, 2006 | 06:56 AM
Juiced2000SS's Avatar
Maybe a muffler shop could expand the Y for you a bit to slip over the collector. Or if you can just spring for a new Y. Just so you get the best possible seal, and you can easily remove if ness.
