Power Steering pump question
Old Mar 11, 2006 | 12:02 AM
KurtRardin's Avatar
Veteran: Marine Corps
Default Power Steering pump question
I guess im in the right area...am i correct in saying that an ss has a different ps pump than a z? Might this make a difference when swapping stock 16" wheels to 275 40 17s? I dont know if its just a coincidence but it seems that i am getting noise from the steering area, plus the pump is wet on the outside, and the pulley has thrown a little little bit of fluid on itself, like it spun out of the center. It doesnt seem to be using any fluid though. Thanks.
Old Mar 11, 2006 | 03:54 AM
anthonyz281999's Avatar
same pump....ss's came with a power steering pump cooler...and i think it was standard on 02 camaro ss's and z28's
Old Mar 11, 2006 | 09:56 AM
WILWAXU's Avatar
I would just clean it up and see if it leaks anymore.
Old Mar 11, 2006 | 10:07 AM
joshp14's Avatar
Depending on where it's wet...it may be that the shaft seal is leaking...very common once you get some miles on them. Go buy a shaft seal for $5 from the dealership and rent a P.S. pump pulley puller from auto parts store and you can have it changed in 5 min.
Old Mar 11, 2006 | 10:23 AM
KurtRardin's Avatar
sweet. I work at advance on the side, so im good there. Thanks for the info. I kinda figured that it would be a little shaft seal. It looks like its leaking a little there and spinning away from it all over the pulley. My guess to the rest of it being wet was it boiling over thru the cap. Thanks for the info!
