Which fuse controls the turn signals and where is it located??
My signals ain't workin' <img border="0" alt="[whiner]" title="" src="graemlins/gr_cry.gif" />
Anybody know where I can check the fuse??
Thanks again guys!
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Thanks again guys!
Re: Which fuse controls the turn signals and where is it located??
If your dash light comes on but does not flash, you have a blown bulb that you need to replace.
Just turn your blinkers on and walk around your car to see which bulb is blown.
I think my car has a short in it. My front left signal light is out and the left blinker doesn't work... but my right blinker doesn't work either! I have had my signal lights to go out before but when one side goes out the other side usually continues to work. I have some bad problems!
Josh S.
Josh S.
Are the signals not working all the way around? Do the day time runnig lights work? Here are some things it may be in the system. Blown light buld, Flasher unit, blown fuse, or a Bad day time runnig light moduel. The fuse for the turn should be on the left side of the dash under the little panel. The flasher unit in under the steering colum panel on the right side of the steering colum. It is kinda hidin in its holder. The day time running light mod., is located behind the radio, the small black box with the two plugs on it. I had this same problem with my 98 and it was the drl mod. Hope this helps.
Doug
LS1-less for now
Doug
LS1-less for now
