Magnaflow tips too close to my bumper.
Other than this minor issue, I'm happy with the quality of the kit. It was packaged nicely and it fit together nicely for a multiple piece catback. I also found out that my old exhaust had a flowmaster muffler. Ever since I bought the car, it seemed louder than a stock LS1...I thought it was because the muffler baffling just rotted out. The more I delve into this car the more I find out what other people have done to it.
Passenger Side
A couple of shots of the tips in relation to the bumper.
I was thinking that I could put some spacers between those black brackets and the frame to lower the tips a bit. As it sits, I can't even slide my girly like fingers between the tips and the bumper without resistance.
if you loosen all clamps and turn the angle of the muffler you will be able to clear up alot of the clearance issues. use a jack to jack up the muffler a little to where the i-pipe clears the panhard bar and then tighten the clamp that goes into the muffler. then tighten the clamps exiting the muffler. the bracket behind the rear tire should be mounted and tightened first while all clamps are loose. If you play with it a little and spend some time on it you should be able to line it up without taking it to a muffler shop.
