water pump diagnosis please!
Old Jun 19, 2002 | 11:03 PM
MIGHTYMOUSE's Avatar
Default water pump diagnosis please!
heres the situation, new are motor went in tonight.. engine runs beautifully.. the problem symptoms
coolant light is on/off but mostly on.
coolant temperature is erratic and all over the map.
coolant coming from the overflow during first minutes of a hot restart
coolant coming from the weep hole during the first few minutes after a shutdown.
no water in the oil.. no rise in oil level or change in color.
i have tried one bottle of stop leak and all that did was turn the water from orange to tan <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
help help!
do i need a water pump? who has the best price?
Thanks, DAve
Old Jun 20, 2002 | 07:55 AM
Default Re: water pump diagnosis please!
the water temp also drops when im on the gas.. help!
Old Jun 20, 2002 | 01:00 PM
dfarmercse's Avatar
did you bleed the air out of the system? Make sure you have no air left in the system. You may have a bad water pump if you have fluid coming out the weep hole.
Old Jun 20, 2002 | 02:55 PM
i just ordered one from valvegod for $80.. what a deal!
i think that being put on 4 different motors just took its toll.. it lasted 57k miles anyways..
Old Jun 21, 2002 | 12:16 AM
blazinredls1's Avatar
ttt
