My Borla Rattles?
Old Jun 20, 2002 | 02:59 PM
Blue Fire's Avatar
Default Re: My Borla Rattles?
ROFL please dont do that friend your Borla is fine just take it to a shop and tell them where about it's giveing you problem's and what it doing. thay should be able to fix it or put a little heat on it and bend it where every the problem is i have a Borla and *verry* happy with the set up <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> that problem is easy to fix my friend i hade mine put on with no problem's if anything take it back and tell him to loosen up the bolt's and try to move the pipe in the muffler a little more than tighten everything back up. if you go streight pipe that willl sound like Poop <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> yea i wouldent bro not stright pipe anyway <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> if that dont work the gye did not install it right........ give me a yell back and let me know what happen or what's the problem with it <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jun 20, 2002 | 04:14 PM
NastySSoo's Avatar
Hes right dude! Just get it adjusted properly, maybe a few tack welds if nec., and all will be fine!
Old Jun 20, 2002 | 05:33 PM
11 Bravo's Avatar
Mine would rattle on the pipe that goes over the axle. Just had to loosen the pipes up and re-adjust them. Probably a better solution than cutting your Borla off lol
Old Jun 21, 2002 | 12:53 AM
.....00Z28.....'s Avatar
Default My Borla Rattles?
My borla catback rattles all the time when i take off or turn fast. Ive tried everything to fix it, but nothing works. I am thinking about cutting it out and just leaving it straight piped from the y-pipe. I have stock manifolds, gutted cats and an slp y-pipe. Do you think i would have enough back pressure or is this just a stupid idea? I plan to dump the exhaust right out of the y-pipe. I dont care about emissions. What do you think?
Old Jun 21, 2002 | 02:44 PM
Thanks for the input guys..........Ill try to readjust the catback when i get back from Aruba. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jun 22, 2002 | 12:42 AM
5150Z28's Avatar
Keep adjusting it until it stops rattling. The Borla catback on my car has been on there for a year and it doesn't rattle one bit and it's not even welded.
