HELP!! Need part # for a bearing for my A/C tensioner.
Go to Checker/Shuck/Kragen and see if they have a replacement one. Not sure if it is the same one you need, but I bought the pulley with bearing for less than $10.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Phil, are you sure it's your AC tensioner, sometimes it's hard to tell if it's the AC tensioner or the idler pulley making the noise.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DARK AGE 53:
<strong>Phil, are you sure it's your AC tensioner, sometimes it's hard to tell if it's the AC tensioner or the idler pulley making the noise.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm not sure its the idler pulley or not. I'll squirt WD-40 on the lowermost pulley (closest to a/c comp) and it quiets it for a little while. What do I need?
If you sprayed some WD-40 on the pulley and the noise went away for awhile it sounds like that should be it, the reason I asked about the idler pulley is there's been several guys who have had a problem with them in the past. Good luck.
<strong>If you sprayed some WD-40 on the pulley and the noise went away for awhile it sounds like that should be it, the reason I asked about the idler pulley is there's been several guys who have had a problem with them in the past. Good luck.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">There's a TSB on the idler pulley
