Help: Throttle cable too much slack after maf swap.
Old Jun 26, 2002 | 09:15 PM
andy98Z's Avatar
Default Help: Throttle cable too much slack after maf swap.
I put my ported 98 Throttle body on my new 00 SS now when i floor it there is a 1/2in gap in front of the bump stop. I can tell the metal on the 00 tb is longer to stretch the cable more. Can I shorten the cable or what>
Old Jun 26, 2002 | 09:25 PM
jmX's Avatar
jmX
Default Re: Help: Throttle cable too much slack after maf swap.
Do you have traction control?
Old Jun 26, 2002 | 09:33 PM
andy98Z's Avatar
Yes I do.
Old Jun 26, 2002 | 10:17 PM
andy98Z's Avatar
I pulled that plastic off the cruise/traction control box played iwth it alittle. Decided to put my old TB on and now the car goes 30mph without touching the pedal!
Old Jun 26, 2002 | 11:24 PM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
You can't use a 98 TB 0n a 00 car or vice versa.
Old Jun 26, 2002 | 11:35 PM
andy98Z's Avatar
You can if you swap the TB cam and linkage holder thing. I just want to know why my cable is so tight now when I put the 00 one back on,
Old Jun 27, 2002 | 09:42 AM
andy98Z's Avatar
ttt-
Old Jun 27, 2002 | 08:34 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by andy98Z:
<strong>You can if you swap the TB cam and linkage holder thing. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's the reason most people have problems swapping different TB's form one year to another.
Why couldn't GM leave the F'n TB cam the same for all LS1 F-bodies???
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jun 27, 2002 | 09:06 PM
MIGHTYMOUSE's Avatar
tie a couple knots in the sucker.
Old Jun 27, 2002 | 10:24 PM
Jantzer98SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MIGHTYMOUSE:
<strong>tie a couple knots in the sucker.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">LOL!
I'm not sure what your problem is. Maybe it's betting kinked under the hood somewhere. I've had my throttle stick before.
Old Jun 28, 2002 | 07:12 PM
Dipstick's Avatar
My 99 has an adjuster about 18" from the throttle body. See if you can get/take some slack in/out with that.
Old Jun 29, 2002 | 10:06 AM
SLowETz's Avatar
Follow the T.cable back until you get to a plastic clip. Remove the clip, have someone push the pedle to the floor, then adjust the T.cable by pushining in or pulling out until the TB blade is all the way open against the bump stop.
Had to do this when I realized that my TB blade was only opening 75% from the factory, and again when I did the bump stop mod. Seemed to work fine for me. Hope this helps.
