To Disable Fuel & Ignition for Compression Test
Old Jun 30, 2002 | 03:46 PM
SNW Vette's Avatar
Default To Disable Fuel & Ignition for Compression Test
Hi,
I want to do a compression test. Can I pull the connectors for the coil packs and the injectors to disable the ignition and fuel? Is there something else that needs to be done before cranking?
Thanks for your help,
Steve
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jul 1, 2002 | 09:56 AM
WILWAXU's Avatar
Default Re: To Disable Fuel & Ignition for Compression Test
ttt
Old Jul 1, 2002 | 02:37 PM
SNW Vette's Avatar
Hi,
Thanks for the replies,
I did the compression test after disconnecting both coil pack connectors and all of the injector connectors (8). The test worked find and I saw no codes.
Bye for now,
Steve
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jul 2, 2002 | 12:08 AM
MIGHTYMOUSE's Avatar
yes that will work fine, or just unplug the injectors.. the spark will not work since you will have the plugs out <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
