Turning on fans earlier
Thanks
<strong>Where does the SLP fan switch plug into the stock harness? Do you have to drill the firewall? If you leave the switch turned on, will the fans run anytime the key is switched on?
Thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I havent routed mine yet sense my car is now down but the fans will run if the switch is on regardless if there is a key or not.You will have a low setting a high setting and off.
Do yourself a favor and keep a "snake" wire in that hole! I cut a slit in the plug and ran my wires through it. I left a wire in there that's not connected to anything. When I need to run new wires, I tape them to the snake and gently pull them through.
Works great so far, just make sure the plug doesn't pop out ( you can feel it on the inside to make sure it's still in place)
Mark
