Grotts on the way...
Just get the car high high high up in the air, pull the oil filter and drain plug, and you can get those headers in with no sweat. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
-Andrew
When you have some time, can you PM me, step by step how you installed the Grotts?
Thanks
Nick
Jason
Passenger goes in alot easier. Bolt them up, replace plugs if you want, AIR, and then zip tie wires out of the way. Check everything 10 times, and then fill with oil & filter, connect battery, and fire it up with open headers, & **** off the neighbors. Drive to the muffler shop & get a custom Y. Do not use the crappy Grott Y.
It's as simple as putting them on the same way you take off your stock ones.
Yes you do have to remove the oil filter and drian plug. So just be ready for an oil change.
Instead of lifting the whole front end up in the air.
Just get your jack, and about a 4 inch piece of 4x4.
Jack up just the drivers side as high as you can get it like that. then put a jack stand on a concrete block. To support it, and be safe. But with the car at that angle and up that high it slips right in.
If ya get stuck you can e-mail me to. or send me a pm,
Yes I am getting a custom Y put in.
Does anyone have a pictoral of taking the stuff out? I've NEVER done this and want to be on the safe side. And what all needs to be disconnected again?
Nick
