Has anyone used this exhaust?
Hangers didn't fit where they were supposed to, pipes where too long in some areas, the y-pipe directly after the axle was not bent remotely close to the angle it needed to be, three band clamps were to big (at the stock y-pipe and at each tip), not to mention the chambered pipe in the I-pipe channel banged the hell out of the under-body. Plus, the over the axle pipe could be adjusted so that it wouldn't hit the axle, but after a two or three days of driving, would loosen up and smack the axle on every bump. Some of the band clamps simply wouldn't stay tight. I'm 6'3" and weigh 220lbs and I was torquing the clamps down so hard I thought for sure I was going to strip them.
I finally had to take it to a local shop and have the whole damn thing adjusted and welded to fit. My tips hang too low IMO, but I'm going to live with it for now and see if I can some how get them to lift them a bit later on.
In retrospect... I buy a different exhaust.
Marc
Marc
It's really a damn shame when a manufacturer writes "may need some fabrication" into their directions. They weren't much help on the phone either.
Thanks again for the assistance....the battle resumes!
The shop's telling me that the tips are hanging low 'cause there's no way (without futher fabrication) to get the passenger side tip any higher without looking stupid. So, they got the best fit they could on the passenger side and matched the driver side so it wouldn't look lopsided.
I'll have to get under the car and look real close, but I'm thinkin' that maybe I could sawzall a good sized slit in the bottom of each pipe (behind the chambers), lift the tips 'til they're a bit higher and then weld in a wedge where the slits are. I dunno.
Marc
F that!
If every other company can manage to create a simple catback that hooks right up to stock hangers, comes with all the parts, and doesn't require potential custom work from an exhaust shop, how in the HELL can Stainless Works justify selling their product for that much when they can't even accomplish those qualifications?
F that!
Marc
