ASP need help.......
Old Jul 4, 2002 | 11:24 PM
02SS #0568's Avatar
Default Re: ASP need help.......
Think about riding a ten speed bike and you are the engine pedaling the cranksaft,... the smaller gear on the front (smaller crank pully, underdrive) makes it pedal easier. Also a larger gear on the back (larger alternator pully, overdrive) was needed to make it easier to pedal but would not go as fast.
Good for horsepower; smaller (underdrive) crank pully and larger (overdrive) alternator pully. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
No charging problems with manual trans and mild electronics. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jul 5, 2002 | 12:40 AM
Fahad's Avatar
Default ASP need help.......
what are the diffrence between those two :
1) ASP Underdrive Alternator Pulley.
2) ASP Overdrive Alternator Pulley.
Old Jul 5, 2002 | 12:48 AM
DriveATransAm's Avatar
under=rotates less
over=rotates more <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
or thats what i would take it to mean anyways <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
The Emperor Of Darkness's Avatar
you need the underdrive crank pulley which gives you more horsepower, it is smaller so other stuff running by it get less power which free more hp=better performance. it come in a package with alternator pulley as well.
Old Jul 5, 2002 | 12:50 AM
OBSSSD's Avatar
Underdrive cuts your voltage even farther - stay away from this one.
Overdrive gives you back what you lost in charging capacity with the underdrive crank pulley. This isn't necessary unless you have a big stereo system.
1 post per subject = good <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jul 5, 2002 | 06:38 AM
TagUK's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 02SS #0568:
<strong>No charging problems with manual trans and mild electronics.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Does that imply there would be problems with an automatic?
I've been looking at the ASP product (948500) as part of an initial set of mods (lid/ram air/maf ends/suspension).
1. Is it worth doing or does it create other problems?
2. Does the 948500 product include everything required?
2000 SS daily drive
Old Jul 5, 2002 | 08:54 AM
02SS #0568's Avatar
The 948500 comes w/ the crank pully only. You will also need to replace the belts and the crank bolt, any parts store should have them.
With the lower idle rpm of the auto trans it slows the alt down even more. ASP makes an alt pully that will help if it becomes an issue for you but it should be ok with the crank only and mild electronic upgrades. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Jul 5, 2002 | 01:59 PM
for auto, it's better to have crank pulley only to avoid charging problems.....
 Michael S. Palmer
Old Jul 6, 2002 | 12:36 AM
i have an auto with the crank underdrive only and have no charging problems <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
