O-ring on throttle body missing, revving high!?
Old Mar 21, 2006 | 04:40 PM
Dustin's Avatar
Default O-ring on throttle body missing, revving high!?
Took my throttle body apart and when I was pulling the throttle shaft out and a Metal o-ring flew off. I didnt see where it came from and didnt know where to put it back. I re-assembled the throttle body without it to see what would happen and it revs extremely high! Where does the o-ring go! Pics would be great.
Old Mar 21, 2006 | 06:38 PM
TheBlurLS1's Avatar
That's what she said...
Probably goes in the IAC hole at the very top on the right. Its the thing with the little rubber plunger on the end. I left mine out one time and my idle was going nuts. Is it about the size of a quarter/nickel?
Old Mar 21, 2006 | 07:37 PM
Dustin's Avatar
That sounds like it. I will check in the morning and post back up. Thanks.
Old Mar 21, 2006 | 09:18 PM
Dustin's Avatar
No thats not it. Its not a rubber o-ring, its a metal o-ring or washer. Either came from the TPS sensor or the left side of the tb.
Old Mar 21, 2006 | 09:25 PM
Crazy Man's Avatar
All that o ring does is hold the throttle shaft in place. Its probly not that causing your issue... Anyway after you put the throttle shaft back in put the o ring on the end of the throttle shaft where the tps goes and tap the oring down to the base of the shaft with a socket and a hammer. Put the tps back on and you should be set...
Old Mar 22, 2006 | 09:30 AM
jmm98LS1's Avatar
^^^^ You don't even have to put that washer back on. I think Bo White always left that washer off after he ported throttle bodies.
Old Mar 22, 2006 | 09:43 AM
Dustin's Avatar
So if that washer isnt my problem then what could it be??
Old Mar 22, 2006 | 10:41 AM
jmm98LS1's Avatar
There's some sort of vaccuum leak somewhere. Check the seal between intake/tb, maybe IAC plunger? All vaccuum connections to tb tight?
Old Mar 22, 2006 | 02:00 PM
Dustin's Avatar
I will check.
Old Mar 22, 2006 | 02:41 PM
Dustin's Avatar
So I checked the seal around the tb and its pretty tight. I did however put my finger over the stick drilled hole in the tb plate and the car calmed down alot which leads me to believe it is a vacuum leak. But the damn car is so loud with the td's that I couldnt hear a leak if i had perfect hearing. Any suggestions?
Old Mar 22, 2006 | 02:59 PM
jmm98LS1's Avatar
I'm assuming since you had the butterfly shaft out that you ported your tb? Did you make sure not to get too close to where the butterfly seals against the tb housing? Guess I'd just double check all fittings to the tb and make sure they're tight?
I hear ya on the loud exhaust deal. Grab some fuel line and use it like a stethescope (sp?) to see if you can hear any leaks.
Old Mar 22, 2006 | 03:29 PM
Dustin's Avatar
Its sealed, i pulled it a little while ago and checked that but its good.
