Torque spec for headers?
Old Jul 8, 2002 | 09:44 AM
99ZEOD's Avatar
Default Torque spec for headers?
Just want to make sure I'm not gonna screw anything up. What should I torque the header bolts down to. Also, any tips for installing Macs with ORY?
Old Jul 8, 2002 | 09:55 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: Torque spec for headers?
I can’t remember the sequence, but I know it was 11ft-lbs on the first pass and 18ft-lbs on the second (and final) pass.
Old Jul 8, 2002 | 11:26 AM
TA_2001's Avatar
here is the detail
http://ls1info.com/article.php?sid=117
a.Tighten the exhaust manifold bolts a first pass to 15 N·m (11 lb ft).
Tighten the exhaust manifold bolts beginning with the center two bolts. Alternate from
side-to-side, and work toward the outside bolts.
b.Tighten the exhaust manifold bolts a final pass to 25 N·m (18 lb ft). Tighten
Old Jul 9, 2002 | 12:46 AM
scottywheels's Avatar
Army EOD, did you attend our dive school or are you surface EOD.
<small>[ July 08, 2002, 12:50 PM: Message edited by: scott ws6 ]</small>
Old Jul 9, 2002 | 06:06 AM
99ZEOD's Avatar
No diving for me. I'm all surface.
Old Jul 9, 2002 | 06:51 AM
StevieZ's Avatar
Take off the air pipes, EGR, coils and valve covers and they will go in smoothly from the top.
