just got lid, need some help PLEASE...
Old Jul 9, 2002 | 11:06 PM
i8a4rE's Avatar
Default just got lid, need some help PLEASE...
ok... i got an ls1 motorsports direct flo lid for my 2002 z28. installation was pretty easy...and then... exactly where am i supposed to mount the old hose that connected to the silencer thing? i attatched the little filter on it but have no where to mount it. also, i tried to close the lid once attatched to everything. but it only closes if i take out the tray that holds the air filter. do i need that tray?...one more thing, i forgot to order the oil/cleaner stuff with my holly filter, it says never to use it without the oil...true?PLEASE HELP ASAP...THANKS IN ADVANCE...
Old Jul 9, 2002 | 11:31 PM
VIP1's Avatar
Copy & Paste Moderator
Default Re: just got lid, need some help PLEASE...
I cant answer all of your questions, but I can help with the one about filter oil. If the filter came oiled (ie: K&N and Holley Powershot), then dont use it without the filter oil. The oil is there to trap dirt. Without it, too much dirt will pass through into your engine. That is a bad thing. Also, use the manufacturer's oil (ie: K&N filter with K&N filter oil and Holley Powershot filter with Holley Powershot filter oil). Just follow the cleaning and oiling instructions supplied by the manufacturer. Otherwise the warranty on the filter is void. I personally have the Holley Powershot filter, but have only had it a few months and dont need to clean and re-oil it yet.
--VIP1
Old Jul 10, 2002 | 03:05 AM
hondakiller's Avatar
you can mount that hose whereever you want to. its up to you ziptie it out of the way somewhere. to get my lid on i pull the filter forward in the tray so i can get the tabs on the lid in then i push it back and it closes up fine. youll need the oil eventually and even more often if youve done the FRA mod or have an FTRA. you suck in some serious air with that mod. the oiling is easy but it takes a while because you have to let it air dry after washing it and then you have to let the oil dry so it wont mess up your maf wires.
Old Jul 10, 2002 | 01:15 PM
02 Pewter LS1's Avatar
i8a4rE
Was your Lid all scratched up on the front of it?
I just got mine and it had scratches on it. It is a nice looking piece other than that. I zip tied mine to the stainless brake line between the Abs unit and the strut tower with filter facing up.
Old Jul 10, 2002 | 01:23 PM
CHRISPY's Avatar
you need to push the lid back a little further towards the engine for it to close properly. Hope this makes sense <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Chris
Old Jul 10, 2002 | 02:57 PM
i8a4rE's Avatar
hey pewter,
Old Jul 10, 2002 | 03:01 PM
i8a4rE's Avatar
ooops...anyway, mine was fine but, after trying to put the clips on there were some scratches. maybe they sold you a used one..even if it is used though, it should still work fine. i love this mod, now i'll just have to order ther cleaner DAGNABIT. I'M USING THE STOCK FILTER RIGHT NOW...BLEH
Old Jul 10, 2002 | 04:01 PM
Mean Machine's Avatar
maybe i'm wrong, but i believe that the holley powershot filter comes pre-oiled from the factory. the holley filter oil is blue hence the blue filter element. i just cleaned mine the other day and after washing it, the filter element turned white in places. re-oiled it, back to blue.
Old Jul 10, 2002 | 04:45 PM
i8a4rE's Avatar
well if that's true i'm gonna drop it in right now...how long before first oiling?
Old Jul 10, 2002 | 05:08 PM
RICHS_Z28's Avatar
im sure they come oiled. i got a k&n filter and it was oiled already. u should be able to tell just by touching it. if it feels oiled then throw it on. <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Old Jul 10, 2002 | 07:14 PM
WILWAXU's Avatar
Here is a great write up on lid installs to help easier explain with pictures <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Lid Install
Old Jul 10, 2002 | 09:59 PM
VIP1's Avatar
I have a Holley Powershot filter and it came oiled. Others I know also have Holley Powershot filters and they cam oiled too. As mentioned above, the filter is actually white, but the oil is blue. Thats why the filter looks blue. I think the manufacturer suggestes yearly cleaning and re-oiling.
--VIP1
Old Jul 11, 2002 | 12:28 AM
i8a4rE's Avatar
ok, i just fixed everything. i mounted it on a little notch connected to the radiator...so now i started my car for the first time and it sounds like it's whining under the hood.normal? or is it just all the pullies spinning loud?????
Old Jul 11, 2002 | 12:44 AM
numbZ's Avatar
That sound is probably just the extra intake noise from removing that giant stock air silencer. Go drive it and listen from inside the car and you`ll probably like the new sound.When I put my FIPK on it was music to my ears.
Old Jul 11, 2002 | 12:51 AM
i8a4rE's Avatar
yeah i thought it might be..i was just expecting a different noise. iwas a little scared to drive it since this was the first time i ever touched anything under the hood by my self. i hope everything is okely dokely... thanks fellas
