Highest # Injectors i can use???
Old Jul 12, 2002 | 09:20 PM
RTCamaroSS's Avatar
Default Highest # Injectors i can use???
I have a 99 SS.. mods are in my sig. I have some abnormally noisy injectors, so im going to replace them. Im also going to be spraying a 75 shot soon.. Wondering what a safe # injector is to run without having to get my PCM totally reprogrammed.. Ive found some good deals on Ford SVO 30# injectors.. can i run these with no problems? im not going to be using the nitrous often.. so these will be used with the mods listed below.. What replacement injectors do you recommend for me??? Anyone have a good set you want to sell me? Need em soon...
Old Jul 13, 2002 | 03:40 AM
ChrisB's Avatar
Default Re: Highest # Injectors i can use???
As long as you stick with high impedance injectors you are fine. You will need some sort of programming to compensate properly for the fuel injector flow rate change. The 30's are a fine choice. I wouldn't really go much bigger than you need as you will loose dynamic range.
Chris
