Asp crank pulley
http://www.fryrice.com/images/aspmafsmall.jpg
Be sure to check it after you install it. Some have had problems with the pully wobbling (sp?), which can throw off the harmonics off the engine. But I think that was a problem early in production.
Justin
As long as the pulley is installed correctly, you should be just fine.
Jason
The install is easy IF you have the correct tools. You will need a 3-jaw puller and a 24mm socket. A flywheel lock and a torque angle meter are also recommended.
Jason
<strong>You also need a new crank bolt.
Jason</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Do you need to replace this bolt anytime the ASP crank pulley is removed and reinstalled?
Mike
<small>[ July 18, 2002, 10:13 PM: Message edited by: Brownie ]</small>
Here is the process for installing a pulley on an LS1:
-Remove bolt and pulley
-Install new pulley and use the old bolt to seat it by torqueing the bolt to 240lb-ft.
-Remove old bolt and install new bolt.
-Torque this bolt to 37lb-ft and then an additional 120 degrees.
http://www.community.webshots.com/user/jr3334z28
<strong>Whats a fly wheel lock and angle meter and how do you get it torqued down that tight?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Since you have a M6 just put the car in 6th gear and pull the e brake, it will hold the motor to break it lose. Thats what I did when I did mine and when I did the cam. Then just leave it there and it will hold up to torqueing down the bolt as well
<small>[ July 22, 2002, 04:23 PM: Message edited by: bd mnky ]</small>
