Question on FLP headers
Old Mar 25, 2006 | 01:51 PM
nvmy2000ss's Avatar
Default Question on FLP headers
I own a 2000 camaro and purchased a set of FLP headers for a 01-02 camaro or transam, I just couldnt pass up the 400 dollar price with cats and race pipes.
I installed the headers with no fittment problems BUT the problem I did run into were the air tubes that bolt to the top of the headers, They just dont fit well. Rather than trying to cut and weld or bending the hard *** stainless steel, I was wondering if I change to the ones from an 01-02 camaro would work? They are diffrent correct?
Any help would be great.
Thanks
Old Mar 25, 2006 | 06:26 PM
calongo_SS's Avatar
Yes that should take care of the problem. You should be able to bend the tubes you have though. Why not do the !air mod?
Old Mar 25, 2006 | 06:58 PM
nvmy2000ss's Avatar
Unfotunatly I live in CA and its much easier to go back to stock for the visual than tear all of it out. Thanks
Old Mar 28, 2006 | 07:47 AM
WILWAXU's Avatar
Hmm.. the '00 use the same AIR tubes as the '01-'02's. Might want to try using some '98-'99 tubes. All you need is the stainless tubing. I'd suggest finding them used.
